MIAC ADC Channels
Nazaire VERRUE
Been thanked: 3 times
MIAC ADC Channels
Post by Nazaire VERRUE »
Dear,
The channel of the properties from knob_ptr_black1 is not correct.
In the properties of knob_ptr_black1 is channel AN1 connected with I7. See IC
In the Miac module is channel AN1 connected with I2.
See attachment Oefening4.fcfx
What is it wrong?
(16.74 KiB) Downloaded 5050 times
Best regards
Nazaire Verrue
Oefening4.fcfx
(6.76 KiB) Downloaded 337 times
Re: The properties of knob_ptr_black1
Hi Nazaire,
Goto agree with you about this.
So I have attached an unofficial modified file to replace your existing MIAC.fcdx file
Goto C:\Program Files (x86)\Flowcode 6\FCD\PIC (if 64bit windows)
or
C:\Program Files\Flowcode 6\FCD\PIC (if 32bit windows)
Back up original MIAC.fcdx then replace with attached version.
Modified file will assign An1 to An8 to I1 to I8 respectively.
Not sure if that was the original intent, but I thought it would make sense.
A tip:
If you want to see the exact ADC value of pot then goto View menu and select Analog Inputs.
MIAC.fcdx
(17.47 KiB) Downloaded 357 times
Nazaire VERRUE
Hi Martin
I have replace MIAC.fcdx.
In the properties of knob_ptr_black1 is channel An1 connected with I1. See IC
In the Miac module is channel An1 connected with I2.
Jou must modified file with An0 to An7 to I1 to I8 respectively and not An1 to An8
Best regards
Nazaire
Re: MIAC ADC Channels
Hi Nazaire,
Not 100% sure what your saying.
On my flowchart, I can select channels An1 = I1 to An7 = I7
(52.64 KiB) Downloaded 5018 times
Unless that's not what you wanted?
Only the analogue input slider has An0 as I don’t believe I can eliminate An0, but not sure about that?
So if I select An1 then I1 will be the input.
Are you saying that is not the case?
If so then I can’t check this until I get home this evening.
Nazaire VERRUE
Hi Martin
When i load the software in the Miac module then is An1 connected with I2 and not with I1
In the flowchart is An1 connected with I1.
See attachment Oefening4. fcfx
Wat is it wrong?
Best regards
Nazaire
Oefening4.fcfx
(6.76 KiB) Downloaded 350 times
I will double check all the channels on hardware tonight when I get home.
Unless it can be checked and sorted by someone before I get home that is.
Martin.
Has thanked: 481 times
Been thanked: 699 times
Here’s a corrected MIAC fcd
Leigh
MIAC.fcdx
(17.47 KiB) Downloaded 351 times
Nazaire VERRUE
Thanks Leigh
Now it work correct
Best regards
Nazaire
