Interupt Settings
acestu
Has thanked: 783 times
Been thanked: 223 times
Interupt Settings
Post by acestu »
I need to change a chart after 20 mins, so I am using an interrupt with Timer0, however I can't see how I set the period in the settings window, could somebody help me please ?
(12.48 KiB) Downloaded 2588 times
cheers
Acestu
Creative25
Has thanked: 166 times
Been thanked: 26 times
Re: Interupt Settings
Post by Creative25 »
This is what I did.
I use timer two.
Prescaler1:16
Postscaler1:5
Rollover value 32
At32MHz this gives a frequency of exactly 3125Hz
Then use I used counters to make seconds and minutes.
If it does not have to be so precise you can also use Timer0
I have atached the macro I used.
Best Regards:
Uli
seconds.fcm
(3.44 KiB) Downloaded 284 times
acestu
Post by acestu »
Hi Creative,
Thanks for posting the Macro, I have imported it but I can't find it lol :lol: , where does it end up ?
cheers
Acestu
Hi Stuart,
I have posted a flowchart that toggles an output every 20minutes using a 19.6609MHz xtal.
With interrupt set at 75.00Hz, this means interrupt macro is accessed 75times evey second = once every 1/75 = 13.33ms
Its always best to choose the lowest interrupt frequency that is rounded to the nearest whole number.
75.00 is perfect!
20mins.fcfx
(8.2 KiB) Downloaded 303 times
acestu
Post by acestu »
Hi Martin,
Thanks for the chart, I will have a look at it now :D
cheers
Acestu
Creative25
Hi Martin Thanks
I see the 19.6609MHz xtal gives some nice interrupt Frequencies and makes things easier.
I am using the Internal Oscillator at 32MHZ , the only Frequency I found that has no decimal point was 3125Hz. I realize it is slowing down the program unnecessarily.
Is there a simpler way to create a 1 Minute counter without External Oscillator, and without using such high interrupt frequency?
Best Regards:
Uli
