Data interchange with Wiz610wi
PICFriend
Post by PICFriend »
Im searching for a possibility to interchange data with two wiz610wi devices, but i don´t know what to do!
I try to explain what i want to have:
I got a LED and a button connected to the PIC18F2685 and this PIC also does handle the WIZ610wi via Flowcode WEBserver component.
This breadboard test setup i got two times. The WIZ610wi are running in client mode with static IP´s and port 5000.
They are sucessful listet in the router connections and the webservers are running. I can switch a LED with html buttons. So far.
Now i want to interchange Bytes variables between these two test setup´s.
Example: Press the button on the first test setup it lits the LED on the second setup, and back.
Is it possible without use of html or requests to a homepage?
Can you show me a way to do this?
What about the use of TCP or UDP?
Please help me - i´am using Flowcode 5.4.00
regards from germany
Carsten :wink:
