Miac Extended can communication (29 bit adress)
Nazaire VERRUE
Been thanked: 3 times
Post by Nazaire VERRUE »
Dear,
I have made an extended can communication with two miac modules.
See attachment: Oefening22a.fcfx (send the can communication) and Oefening22b.fcfx (receive the can communication)
With an adress = 10 work the can communication perfect.
With an adress = 217056256 work the send can comminication perfect (Oefening22a.fcfx) but the receive can communication will not work (Oefening22b.fcfx).
What is here wrong?
Best regards
Nazaire Verrue
Oefening22b.fcfx
(12.03 KiB) Downloaded 356 times
Oefening22a.fcfx
(10.46 KiB) Downloaded 364 times
Last edited by Nazaire VERRUE on Mon Oct 14, 2013 7:45 pm, edited 1 time in total.
Has thanked: 481 times
Been thanked: 699 times
Re: Miac Extended can communication (29 bit adress)
Yes, it’s a bug in the CAN component, now fixed and attached (will also be in the next patch release)
Leigh
CAN.fcpx
(20.11 KiB) Downloaded 384 times
Nazaire VERRUE
Dear Leigh
The file CAN.fcpx will not work.
I have downloaded the CAN.fcpx and this replace in the software but the CAN component will not add to the dashbord panel.
What is here wrong?
Best regards
Nazaire Verrue
That could be a licensing issue. Do you have the Professional version?
Nazaire VERRUE
Dear Leigh
I have the Professional version of flowcode 6
Best regards
Nazaire Verrue
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Post by JonnyW »
There was a change in file format to support multi-arrays in 6.0.2. It is possible that this is causing the issue if you are running a pre-6.0.2 version. If you make sure you are on at least 6.0.2 then this should help. The latest is 6.0.3.
You can upgrade via your account or through Help->Check for Upgrades in Flowcode.
Jonny
Nazaire VERRUE
Thank you Jonny and Leigh
Now it work perfect.
Best regards
Nazaire
