Serious Warning: Possible sw stack corruption.
beejo
Has thanked: 4 times
Post by beejo »
Is there anyone who has experience with the use, in the same program, of a hardware Uart and a software Uart from the PIC16F877A for reading, editing, and sending data of a RS232 device to another RS232device?
I've been a long time experimenting. Now I notice the following warning messages in the compile posts.
During the compilation i notice the following warning :
Serious Warning: Possible sw stack corruption, function 'FCD_RS2320_ReceiveRS232Char' called by more than one asynchronous thread (main/Task, interrupt, interrupt low)
Serious Warning: Possible sw stack corruption, function 'FCD_RS2321_ReceiveRS232Char' called by more than one asynchronous thread (main/Task, interrupt, interrupt low)
Does this mean that the Interrupt is not working properly. In other words that the correct stack info is lost? Because I can't read any good data string into the PIC.
How can I solve this Mega problem?
Please help me quickly with this pressing problem.
Thank in advance,
Beejo
Flowcode V5 user.
RS232communication between 2devices REV E.fcf
(57.22 KiB) Downloaded 369 times
Kenrix2
Flowcode v5 User
Has thanked: 72 times
Been thanked: 177 times
Re: Serious Warning: Possible sw stack corruption.
Post by Kenrix2 »
If you could just change your target micro to one with two hardware UARTs your project would be a lot easier. Another option might be a hardware switching scheme to direct the serial signal between the two devices and just use the hardware UART.
beejo
Post by beejo »
Hi Kenrix2
Thank you for willing to help me .
Yes, your write. But I need a micro with 2x PWM for the motorcontrol and 2 Usart for communication. Then you need soon the Pic18F..K.. models. This series mcu is not programmable with the E06 programmer board. I know it has to be possible to do this with a hardware and a software Uart.
`Another option might be a hardware switching scheme to direct the serial signal between the two devices and just use the hardware UART`
If i direct the commands directly to the other device e.g. make a bypass then i can not modify this signal. So I have to read the commands and add another set of commands depending on that command. But for the moment I would be very happy if there is communication possible between the 2 Usart.
best regards,
Beejo
Kenrix2
Flowcode v5 User
Post by Kenrix2 »
I tried to compile your program using the -sw 6 2 switch and it compiled just fine. here is my linker/assembler parameters which you can copy and paste it : -ld "C:\Program Files\Flowcode\v5\Tools\BoostC\lib" libc.pic16.lib rand.pic16.lib float.pic16.lib "%f.obj" -t PIC%p -d "%d" -p "%f -sw 6 2"
Maybe I am overly cautious but I would be concerned about using the software uart with an interrupt enabled.
beejo
Post by beejo »
Hi Kenrix2,
You got no error message like this in your compilation?
In my assembler/linker option are two differences.
-ld "C:\Program Files (x86)\Flowcode\v5\Tools\BoostC\lib" libc.pic16.lib rand.pic16.lib float.pic16.lib "%f.obj" -t PIC%p -d "%d" -p "%f" -swcs 6 2
The first has to do with the 64 bit machine (x86) and the other difference is:
The software stack key in my linker/assembler parameters is positioned directly after the last character ("). However, I have tested both possibilities and both key notifications give the same error message above at compile time.
Beejo
beejo
Post by beejo »
Hi Kenrix2,
I tried your SW key and finally without stack corruption error so thank you again for this. Maybe i didn't save the compiling options. Also You are write again why make it too difficult I will follow your advise and make a bypass
When certain commands are missing I send them afterwards via the PIC.
But when i read your advise good you mean a switching solution. Do you have an example of this?
Kind regards ,
Beejo
