Hi Guys.
I have been trying my Microchip Explorer 16 board with Flowcode and a Pickit2 (and a Pickit3) so had to try and get the Compiler Options configured for them but I have not had any luck.
I've searched the forum and not found the settings.
I have tried a bit of DIY too based on the configs for Flowcode 4 for the PIC but again not got anywhere.
Anyone know of the settings? Know of a link to the page(s)??
As I said I have Pickit2 & Pickit3 obviously Pickit3 config would be best as it's useable with a greater range of chips, but I'd be grateful for any help.
Many Thanks
Gypo
Pic24 / dsPic & Pickit2 or Pickit3
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
Re: Pic24 / dsPic & Pickit2 or Pickit3
You need to set the programmer options. Compiler settings should be the same.Gypo wrote:Compiler Options configured for them but I have not had any luck.
Strange as I found messages concerning the subject no problem.Gypo wrote:I've searched the forum and not found the settings.
Check these PICkit 2 and PICkit 3. Should work for FC4 when you adapt the paths. Make sure the PICkit3 is set for MPLAB 8 mode, not MPLAB X. (See these messages about settings/firmware for PICkit3)
― C.S. Lewis
― C.S. Lewis
Thanks for these links I'll give them a try,
It looks these are in the Flowcode 5 part of the forum possibly the reason I couldn't find them in the V4 part of the forum.
Thanks again.... Fingers crossed...
The only real simulation isn't ...
Gypo
Gypo
Hi Guys...
Tried the Pickit2 setting but no joy...
Obviously I had to make some changes to the path to allow for the fact that I use Flowcode 4 (I'm using 64bit Windows 7 too).
Settings I have now....
_____________________________________________________________
Programmer Section of Compiler Options window:
Location: = C:\Program Files (x86)\Matrix Multimedia\Flowcode PIC24&dsPIC V4\Tools\PICkit2\pk2cmd.exe
Parameters: = -BC:\Program Files (x86)\Matrix Multimedia\Flowcode PIC24&dsPIC V4\Tools\PICkit2\ -PPIC%p -F%f.hex -M -A5 -R
Location: = C:\Program Files (x86)\Matrix Multimedia\Flowcode PIC24&dsPIC V4\Tools\PPP\PPPv3.exe
Parameters: = -cs 2 -chip PIC%p -config
______________________________________________________________
This is a cut down of what is shown when I try and compile and program the chip (It compiles OK without any errors).
C:\Program Files (x86)\Matrix Multimedia\Flowcode PIC24&dsPIC V4\Tools\MX_bats\pic16_C30_link.bat -BC:\Program Files (x86)\Flowcode PIC24&dsPIC V4\Tools\PICkit2\ -PPIC24FJ64GA010 -FFlowcode1.hex -M -A5 -R
C:\Users\CWT\Desktop\PIC24_Exp16 FC>pic30-gcc -Wl,-BC:\Program.o,-L"C:\PROGRA~2\MATRIX~1\FLOWCO~2\Tools\MX_bats\..\C_tools\lib",--heap=256,--report-mem,--script="C:\PROGRA~2\MATRIX~1\FLOWCO~2\Tools\MX_bats\..\C_tools\Support\(x86)\Flowcode\gld\pFiles.gld",-o-BC:\Program.cof
pic30-coff-cpp.exe: C:\PROGRA~2\MATRIX~1\FLOWCO~2\Tools\MX_bats\..\C_tools\Support\(x86)\Flowcode\gld\pFiles.gld: No such file or directory
pic30-coff-cpp.exe: warning: '-x c' after last input file has no effect
pic30-coff-cpp.exe: no input files
c:\progra~2\matrix~1\flowco~2\tools\c_tools\bin\bin\..\bin/pic30-coff-ld.exe: unrecognized option '-BC:\Program.o'
c:\progra~2\matrix~1\flowco~2\tools\c_tools\bin\bin\..\bin/pic30-coff-ld.exe: use the --help option for usage information
Error returned from [pic30-gcc.exe]
Return code = 1
Flowcode was unable to assemble the ASM file due to the following errors:
FINISHED
The red bit is right that directory doesn't exist but I don't know where it comes from or how to correct it...
This is where the directory really is;-
C:\Program Files (x86)\Matrix Multimedia\Flowcode PIC24&dsPIC V4\Tools\C_tools\support\PIC24F\gld
Gypo
Return code = 1
FINISHED
Gypo
Gypo
Gypo
Benj / Anyone
Does anyone have any suggestions?
Is anyone using a PICKIT2 or 3 with Flowcode 4 PIC24/dsPic and windows 7 ..... If so please, please, please let me know the settings I need......
I know you will be able to answer this one, so please can you help?
I still have the same problem, I have reinstalled the program selecting PICKIT2 as the programmer but it still complains about a directory missing, I can't work out what to change to make it work. Can you please help?
I was going to try and move to PIC24 & 32's but until I get this working I'm stumped...
Gypo
Gypo
Gypo
Gypo
kersing
This error is not related to the PICkit programmer. You need to take a look at the Linker settings (in compiler options), make sure the Linker/Assembler settings are:Gypo wrote: This is a cut down of what is shown when I try and compile and program the chip (It compiles OK without any errors).
**********************************************************************************************************************************************************Code: Select all
Launching the linker/assembler... C:\Program Files (x86)\Matrix Multimedia\Flowcode PIC24&dsPIC V4\Tools\MX_bats\pic16_C30_link.bat -BC:\Program Files (x86)\Flowcode PIC24&dsPIC V4\Tools\PICkit2\ -PPIC24FJ64GA010 -FFlowcode1.hex -M -A5 -R C:\Users\CWT\Desktop\PIC24_Exp16 FC>pic30-gcc -Wl,-BC:\Program.o,-L"C:\PROGRA~2\MATRIX~1\FLOWCO~2\Tools\MX_bats\..\C_tools\lib",--heap=256,--report-mem,--script="C:\PROGRA~2\MATRIX~1\FLOWCO~2\Tools\MX_bats\..\C_tools\Support\(x86)\Flowcode\gld\pFiles.gld",-o-BC:\Program.cof pic30-coff-cpp.exe: C:\PROGRA~2\MATRIX~1\FLOWCO~2\Tools\MX_bats\..\C_tools\Support\(x86)\Flowcode\gld\pFiles.gld: No such file or directory pic30-coff-cpp.exe: warning: '-x c' after last input file has no effect pic30-coff-cpp.exe: no input files c:\progra~2\matrix~1\flowco~2\tools\c_tools\bin\bin\..\bin/pic30-coff-ld.exe: unrecognized option '-BC:\Program.o' c:\progra~2\matrix~1\flowco~2\tools\c_tools\bin\bin\..\bin/pic30-coff-ld.exe: use the --help option for usage information
Location: C:\Program Files (x86)\Matrix Multimedia\Flowcode PIC24&dsPIC V4\Tools\MX_bats\pic16_C30_link.bat
Parameters: "%f" %T %y
(Include the quotes)
― C.S. Lewis
― C.S. Lewis
kersing
Big thanks mate.
For some reason the program had something totally different in the Parameters part of the Linker / Assembler settings even though I had removed and installed the program again.
I changed it to your suggestion and it built the HEX file without problems.
I had a problem with the programmer side of things after that (voltage setting) sorted that out and all is working great now.
For those in the same position as myself I thought I'd share what works for me....
I am running 64bit Windows 7 Ultimate with Pickit2 and the Professional Version of Flowcode Pic24/dsPic V4.4.13.69
These are the settings that work for me in the compiler Options window;
________________________________________________________________________________
Compiler:
Location: = C:\Program Files (x86)\Matrix Multimedia\Flowcode PIC24&dsPIC V4\Tools\MX_bats\pic16_C30_comp.bat
Parameters: = "%f" "%D" %T
Linker / Assembler:
Location: = C:\Program Files (x86)\Matrix Multimedia\Flowcode PIC24&dsPIC V4\Tools\MX_bats\pic16_C30_link.bat
Parameters: = "%f" %T %y
Programmer:
Parameters: = -BC:\Program Files (x86)\Matrix Multimedia\Flowcode PIC24&dsPIC V4\Tools\PICkit2\ -PPIC%p -F%f.hex -M -A3 -R
Use external program to set configuration options = Ticked
The text coloured red needs to be changed for the correct voltage of the chip you are using.
Big thanks mate.
Compiler:
Linker / Assembler:
Programmer:
Gypo
Gypo
