Miac Master-Slave
Nazaire VERRUE
Been thanked: 3 times
Miac Master-Slave
Post by Nazaire VERRUE »
Dear,
I have made a master slave with two miac modules.
In the slave module i have loaded "Slave_280812.hex"
In the master module i will load Oefening24.fcfx (see attachment) but this will not load. There are errors by compile.
What is here wrong?
Best regards
Nazaire Verrue
Oefening24.fcfx
(7.07 KiB) Downloaded 381 times
Has thanked: 481 times
Been thanked: 699 times
Re: Miac Master-Slave
Hi Nazaire,
Unfortunately Flowcode V6 does not yet support the “MIAC System”, and probably should not have been listed as available in the project options.
You can still target a standalone “MIAC”, just chose “MIAC” rather than “MIAC System” for the project target.
The “MIAC System” is intended for the CAN connected MIAC Master, MIAC (CAN) Slave and MIAC Expansion Modules. This target configuration takes over the control of the MIAC CAN feature.
(The MIAC USB Slave is for a USB connected standalone MIAC)
Leigh
Nazaire VERRUE
Hi Leigh
When do jou think to make the Miac System for the CAN connected Miac Master, Miac (CAN) Slave and Miac Expansion Modules?
Best regards
Nazaire
