How to use 2.56 internal reference with attiny861
Please help me to use the 2.56 internal reference with attiny861
There is no option in extension propertise (can only set vref+ and vdd)
i have try to use a c code : "ADMUX=0x80; ADCSRB=0x10;"
Peter
Peter
- Has thanked: 553 times
- Been thanked: 1081 times
Re: How to use 2.56 internal reference with attiny861
Have you tried adding a C code block with those statements? I'm not sure, but I think you need flowcode professional to add C code.
― C.S. Lewis
― C.S. Lewis
yes, i'd already try to add "ADMUX=0x80; ADCSRB=0x10;" as c code, but it was not work.
When i write the program to the uc it only uses the suppy voltage or the extref pins as reference, as i set it in the extension properties, my c code is not matters at all.
Should i modify the "AVR_CAL_ADC.c" ? I think the attiny 861 have "ADC Type 10".
Peter
Peter
Hi Peter,
Yes you will likely have to edit the CAL ADC file if you want the changes to be made. A good way would be to add your edit to the CAL like this.
The ADC type used by your chip can be seen by viewing the Flowcode generated C code. Should be near the top.
Then in the Project Options -> Supplementary code you can switch on your code mod by adding this line to the defines section.
#define MY_CUSTOM_ADC
Otherwise if this is omitted the code will default back to the standard CAL code.
#ifdef MY_CUSTOM_ADC
ADMUX=0x80;
ADCSRB=0x10;
#endif
Hi!
I have do the changes and i got an error message whilecompiling
i think i was pasted the next few lines to the wrong place
My avr_cal_adc.c looks like this: (i have adc type 4, it turned out from my c code)
Peter
In file included from C:\Program Files\Flowcode(AVR)\v5\CAL\includes.c:47,
from C:\BALANC~1\Drill.c:1462:
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_ADC.c:199: error: expected identifier or '(' before 'volatile'
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_ADC.c:199: error: expected ')' before '(' token
C:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_ADC.c:200: warning: data definition has no type or storage class
ADMUX=0x80;
ADCSRB=0x10;
#endif"
/* ADC Type 4 Supported Devices ************************************************************
// Unknown
ADMUX=0x80;
ADCSRB=0x10;
#endif
#ifdef MX_ADC_TYPE_4
void FC_CAL_Enable_ADC (MX_UINT8 Channel, MX_UINT8 Conv_Speed, MX_UINT8 Vref, MX_UINT8 T_Charge)
tris_mask = Channel;
if (Channel > 2)
tris_mask++;
if (Channel < 7)
tris_reg = (MX_UINT8*) &DDRA;
else
tris_mask -= 4;
tris_reg = (MX_UINT8*) &DDRB;
old_tris = *tris_reg;
*tris_reg &= ~(1 << tris_mask); //turn selected ADC on
ADCSRA = (1 << ADEN) | Conv_Speed;
ADMUX = (Vref << REFS0) | (1 << ADLAR) | Channel;
delay_us(T_Charge); //wait the acquisition time
ADCSRA |= (1 << ADSC); //begin next conversion
MX_UINT16 FC_CAL_Sample_ADC (MX_UINT8 Sample_Mode)
MX_UINT16 iRetVal;
while(ADCSRA & (1 << ADSC));
if (Sample_Mode)
iRetVal = (ADCL >> 6); //10-bit ADC
iRetVal |= (ADCH << 2);
else
iRetVal = ADCH; //8-bit ADC
return (iRetVal);
void FC_CAL_Disable_ADC ()
*tris_reg = old_tris; //restore old tris value, and reset adc registers
ADCSRA &= ~(1 << ADEN);
#endif
Peter
Please remove your code and change the FC_CAL_Enable_ADC function (look for ADDED and Original):
Feel free to skip the comments with 'ADDED' and 'Original'.
This should work. I can not test it as I do not have FC5 for AVR installed.
if (Channel > 2)
tris_mask++;
if (Channel < 7)
else
tris_mask -= 4;
// ADDED 4 lines
ADMUX=0x80;
ADCSRB=0x10;
#else
// Original 2 lines follow:
// ADDED next line
#endif
― C.S. Lewis
― C.S. Lewis
Thank you kersing for the syntax correction, it seems it works. The compiler can finish the work without errors.
Tomorrow i will try it with the uc and write the result.
well, it did not work in the uc. do i have to some additional thing?
should i set something at theadditional properties?
If i set the additional code, my program runs, but something is not good at the adc configuration.
I try to read a byte from adc an if that byte is less than 128 one led lights.
If i add a 2V to the adc-s pin the led still lights.
If i add 2,6V to that pin the led still lights.
If i disable the additional code and set the ref voltage to supply voltage and give 2,6V to the adc-s pin the light goes off.
What did i do wrong.
Peter
Peter
Could you attach your Flowcode program (fcf file) and the generated C code for us to have a look at?
― C.S. Lewis
― C.S. Lewis
