I2C stops program
henker
Has thanked: 7 times
Been thanked: 2 times
I2C stops program
Post by henker »
I have never used I2C before, but I just purchased a sensor using the I2C protocol.
According to the Datasheet I need to send the following I2C data:
- Start
- 0x23 -> this is the Slave address
- 0
- 0x10 -> Slave will start measuring
- stop
wait 100 msec
- Start
- 0x23
- 1
+Read High Byte
+Read Low Byte
- stop
SOLVED: (The problem I have that the stop byte is causing the program to stop. As soon as I disable this icon, no problem.)
Also, I'm trying to figure out when to use the MI2C_Transmission_Byte or when to use the MI2C_Send_Byte_Transaction.
Any help will be appreciated
henk
dazz
Has thanked: 474 times
Been thanked: 458 times
Re: I2C stops program
Post by dazz »
Can you please attach your flowchart and attach the datasheet of the device you are using as it will help to see whats gone wrong
Dazz
henker
Post by henker »
Dazz,
I have attached the Macro I have created for this. I just noticed that it is not only the stop byte that stops the program.
Again, I have very little to no I2C experience...
http://www.dfrobot.com/image/data/SEN0097/BH1750FVI.pdf
Page 17 on the pdf shows the sequence of the measurement...
Thanks for the help
Henk
Get_light.fcm
(4.28 KiB) Downloaded 378 times
dazz
Post by dazz »
Can you attach your complete flowchart
Dazz
GTF
Has thanked: 20 times
Been thanked: 52 times
Post by GTF »
The write/read bit should be included with the address byte so that the address will be either 0x46 or 0x47 in high res mode, according to page 7 of the datasheet.
It also appears that the delay needs to be at least 180ms in high res mode if I am reading it correctly.
Grant
edit: also, has the I2C been initialized in your main code, prior to any loops?
henker
Post by henker »
Thanks Grant.
Yes, I issue an "I2C INIT" at the start of my main program.
I will try the 0x46 / 0x47. I didn't realize you have to add that bit to the byte you clock out.
henk
