Fuses for non-standard programmer
bert
Post by bert »
I use an Xwisp programmer which assumes the fuses to be in the hex file.
In my program I've added a C box at the very beginning of the program with the following content:
/* fuses
asm __config 0x3f32
While downloading the programmer complains and says it cannot find fuses in the hex file. I don't read hex but I checked the asm file, and I can't find the config line in the asm file. It is still present in the c file.
So, what am I doing wrong in order to get the fuses (config) in the hexfile?
Any help would be appreciated. I use the V3 (3.1.0.31) 30 day evaluation versiopn.
Bert
try this:
#pragma DATA 0x2007, 0x3f32
You may have to put this in the "defines" box of the "supplementary code" window, rather than in a 'C' icon.
bert
Post by bert »
Thanks Steve, that did fix it.
Nevertheless I still would expect any asm statement added in a C box to be carried on to the asm file. Why didn't that work?
Bert
The "__config" line is not a generic asm statement - it is a preprocessor directive specific to MPASM. Perhaps this is the reason it is not transferred.
Version 3 of Flowcode uses a C compiler that generates a HEX file directly from the C code (via a linker). The "asm" file that is generated is like a by-product of this process, rather that a step between the C code and the HEX file (which was the case in the compiler used by v2 of Flowcode).
