Hi Steve
I have used an 877A to interface with this unit and also have used the rs232.hex file to check all my hardware (All ok, correct response(s) recieved).
The 57600 hz output from my sensor however will not display correctly when plugged into modem connection of the rs232 board....
Copying the text output from the unit using hyperterminal capture and pasting it into the PC connection on the rs232 board allows the text to be displayed correctly to the LCD board.
Two questions:
1- Can I alter the 9600 baud on the rs232.hex file?
2- I would like to take the ascii output from the unit above, seperate the parameters (csv delimited) and use these values within a flowcode routine.
Any suggestions?
Dave
