PIC and Internet
Frank607
Has thanked: 29 times
Been thanked: 15 times
PIC and Internet
Post by Frank607 »
Hi all,
A long time ago I get an idea in my head and it won’t go. :-)
I want to make a simple application to control 4 relays over the internet via the web browser on a computer. I read al lot of information but that information is without FlowCode to program this.
I have a few ENC28J60 Ethernet LAN Modules and I need a PIC Controller.
  • What is the best (normal price) PIC controller what I need to buy ?
  • Can I use FlowCode 5.5 for my idea to program this or do I need FlowCode 6?
  • And most important; is it easy to make this sort of program with Flowcode?
Maybe some strange questions but I try to find out where to start or not to start with this project.
Thanks for your answers and best regards,
Frank
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: PIC and Internet
Post by JohnCrow »
Hi Frank
Have a look at these pages.
Matrix have a basic course and example files these might give you some pointers.
http://www.matrixmultimedia.com/lc_index.php?p=10
Frank607
Post by Frank607 »
Thanks John,
I will read this.
Frank
Frank607
Post by Frank607 »
One more question,
Can I use the TCP/IP Stack and the Web server Components on a regular PIC? For example a 18F4550 or a 18LF2550. (with a ENC28J60 module)
Or do I need to buy Eblocks?
Thanks for the answers.
Frank
JohnCrow
Post by JohnCrow »
Hi Frank
I have used the Internet E-block (Mines the original version compared to what they sell now, but are both included in FC , though only in the Pro version)
If you didn't want to use the E block board you'd need to use the same TCP/IP module that's on the e block to be compatible with flow code component.
I seem to remember I had to use a 18F4550, don't think the 16F877A had enough memory.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
Frank607 wrote:with a ENC28J60 module
The TCP/IP stack and webserver components in Flowcode can only used with WIZ3100 or WIZ5100 modules. The ENC28J60 is not supported.
― C.S. Lewis
