Happy new year to all readers.
Right, I'm planning to build a infrared break beam system to trigger my camera. So, at the moment I'm wanting to know which PIC would be best to use.
I'm kicking off with building the IR transmitter which needs to oscillate at 38Khz. I'd like to use a PIC for stability reasons but also to try and teach myself the FLOWCODE5 program I bought a while ago.
I'd like to stick with MICROCHIP as I have the PICKIT2 programmer.
All suggestions on what PIC to use will be appreciated.
Thanks guys - John
Which PIC to use??
- Has thanked: 460 times
- Been thanked: 523 times
Re: Which PIC to use??
Happy new year too
martin (medelec) found a good selector tool and easy to use too
http://www.matrixmultimedia.com/mmforum ... 370#p36370
you could also use the ECIO range too
http://www.matrixmultimedia.com/ecio.php
steve
steve
Thanks for that.
I had a look at the PIC12F683 but it appears that I would have to buy all sorts of other stuff to program it via my PICKIT2. Just looking for something simple that I could possibly program by ICSP with the PIC on a project board??
Any comments???
Thanks again -John
Any comments???
Thanks again -John
No,JDR04 wrote:I had a look at the PIC12F683 but it appears that I would have to buy all sorts of other stuff to program it via my PICKIT2.
12F683 can be programmed via ICSP and PICkit 2 in situ.
No additional stuff required.
I would like to mention that programming any chip via ICSP may need isolation resistors if using the data and clock lines for use with say switches pots etc.
What I have done if using a pot connected to ISCP data line is:
Two outer ends of pot connected to +5V and 0V. the center of the pot connected to Data pin via 10K resistor.
The data pin is then connected to data of ICSP via a 2.5mm header.
You can't have caps connected to ICSP data or clock lines that could short circuit the signals.
If you can post a circuit, then I can have a look at it for you.
how about this , i never used it in the end tho , used a zif socket for the micro
http://uk.farnell.com/aries/40-526-10/s ... dp/1674772
http://www.matrixmultimedia.com/mmforum ... f=7&t=8718
I can vaguely remember that john has built some camera shutter projects but couldn't find them maybe the guys on here could point you in the right direction.
steve
steve
Hi Guys, sorry for the late response. Family duties ETC.
OK, thanks to everybody so far. Could somebody be kind enough to point me in the direction of a schematic that will show me how to connect the 12F683 to my PICKIT2 for ICSP programming.
If I use ICSP method, does that mean I cannot use the connected pins/bits as inputs or outputs as well or can I carry on as per normal?
I found a diagram in the PICKIT2 manual. Can I use this with the same connections? Also I'm told that it might be wise to have a 0.01uF capacitor across pins 1 and 8 of the PIC?? Correct??
Once again thanks a lot and a hope 2014 is really great for all members of this forum.
Cheers John
Cheers John
- (143.79 KiB) Downloaded 1191 times
