Vinculum 1 USB Host Controller - Component
A forum where Flowcode v6 user created components can be shared, discussed and reviewed.
Jordy101091
Has thanked: 25 times
Been thanked: 188 times
Post by Jordy101091 »
Info:
The Vinculum from FTDI is solution to access USB slave devices such BOMS, keyboards, printers with a low cost MCU.
This component allows you to interact with the vinculum 1.
As far as this component goes it only interfaces with a BOMS or Bulk Only Mass Storage device only.
In the future I can provide support for other slave devices as well.
For now the component has utilizes 14 macros for interfacing a BOMS device:
- AppendStringToFile
- ChangeDirectory
- CheckDisk
- CloseFile
- CreateFile
- DeleteDirectory
- DeleteFile
- Initialise
- MakeDirectory
- MovePointer
- MoveUpDirectory
- OpenFile
- SuspendDisk
- WakeDisk
With this component I have provided a simple datalogger application that logs the temperature Data from a DS18B20 temperature Sensor.
Component Use:
The component can be used by copying the ".fcpx" file into the component directory of Flowcode v6.
Then component can be found under the tap Storage as Vinculum 1.
Future Updates:
Future update for V2.1 will include:
-------- The ability to Check for connected disks.
-------- A methode to Check for Available disk before a component macro is executed, otherwise it will return a error code.
-------- A notification when the connected device can be "safely" removed.
-------- A macro for reading the file size
-------- A macro for reading the disk size (<4GB and >4GB)
-------- The CreateFile will be adjusted so I can be used together with the DS1307 & DS3231 Components
-------- Improvement for all other macro, such as return values to notify for example if a command is executed successfully.
If not all updates can be included in a future update, for the reason it takes to long, I will realize some minor updates such as v2.05.
Help File:
Vinculum 1 USB Host Controller V1.0.zip
Vinculum 1 Help File V1.0
(304.66 KiB) Downloaded 818 times
Download:
Vinculum1.fcpx
Vinculum 1 Component V1.0
(3.89 KiB) Downloaded 793 times
Vinculum1.fcpx
Vinculum 1 Component V2.0
(6 KiB) Downloaded 773 times
ChangeLog:
V2.0 = Added the Ability to manipulate the creation date of a file.
-------- Removed the Macro "CheckDisk", Im not getting this function to work properly
-------- Adjusted the panel-properties so its easier to use.
Example(s):
I have moved the Example file to another pages of this post follow this link: http://www.matrixmultimedia.com/mmforum ... 516#p56516
Tutorials:
Tut #1 Vinculum Communiaction Tutorial
Resources:
Firmware manual --> Right Click and Save To
Video
[/youtube]
[/youtube]
[/youtube]
[/youtube]
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: Vinculum 1 USB Host Controller - Component
Post by JohnCrow »
Hi Jordy
Thanks for the article.
Have you a link to a datasheet on the Vinculum. I've not come across that name before, though I have seen FTDI usb devices, and I have a couple kicking about on the bench. Wonder if they are a similar thing?
Jordy101091
JohnCrow wrote:Hi Jordy
Sure here is the datasheet of the Vinculum 1: http://www.ftdichip.com/Support/Documen ... _VDIP1.pdf
JohnCrow
Post by JohnCrow »
Hi Jordy
Hmm Interesting looking device, afraid I've been tempted again and just ordered one to play with (when I get time). Only £28.50 so not exactly going to break the bank. Don't expect it will be sent out now till next week.
Will let you know how I get on with it.
hyperion007
Has thanked: 49 times
Been thanked: 101 times
Post by hyperion007 »
John, where did you order yours?
JohnCrow
Post by JohnCrow »
I've ordered mine direct from FTDI (They are in Scotland). The address is on page 21 of the datasheet.
I don't know where Jordy ordered his from, but I imagine they must have a distributor in your country.
http://www.ftdichip.com/FTSalesNetwork.htm
Jordy101091
I bought the vinculum from a Dutch webshop that had these modules in stock.
Maybe you could Try buying them from farnell.com
hyperion007
Thanks, I just ordered two from FTDI :)
JohnCrow
Post by JohnCrow »
Hi Jordy
My module has arrived today.
Just a quick question, the jumpers on J3 &J4 are set to pins 1 & 2 (Pull Up - Serial UART)
Is this how you have yours set?
PS
I did notice after I'd ordered mine they are stocked by RS Components for a similar price to the manufacturer.
Jordy101091
Yes that's correct,
J3/ J4 are set as Pull Up.
Don't forget to connect to RTS and CTS line of the module without these connected the module cannot function.
Also (this is a known issue) when setting the serial component to the correct baud (9600) you need to set flow control to OFF.
However the bug in the RS232 component is that the cal_uart that's in this component default back to flow control ON.
You need to use the component debugger tool to expose all used components by the serial component and navigate to the cal_uart and set flow control to OFF.
You need to do this every time you re-open you Flowcode program as long as the bug is not fixed.
Regards Jordy
JohnCrow
Post by JohnCrow »
Thanks Jordy
Jordy101091
The help file is no attached and can be downloaded from to start post.
Regard Jordy
Jordy101091
Later this week I want to release a document where I show you how to communicate with the vinculum 1 using a com port terminal program.
The main point if this document is to let you see how easy it is to communicate with it, also you can see the different responses from the vinculum 1 to these commands.
Regards Jordy
JohnCrow
Post by JohnCrow »
Hi Jordy
Just tried this and I've not been able to find it in the component debugger. How do I find that?
Jordy101091
Hi John the best way to explain it is to create a video:
http://www.youtube.com/watch?v=7LUx4Njoap0
[/youtube]
hyperion007
Is there any way to get support for larger flash drives? I don't have any USB sticks smaller than 8GB. I thought I did but nope.
I even managed to take one of my 8GB USB sticks and create a 500MB partition (only partition) and format it with FAT16 but still no go. It will not create log.csv on it.
JohnCrow
Post by JohnCrow »
My first tests last night, it didn't create the file on a 2GB usb stick either (formatted fat - 64k Allocation Units)
Ive got a 250MB drive somewhere, I'll dig that out and try that tomorrow.
The display showed File Created and the data point counter was incrementing.
Jordy101091
Hi john,
I did a quick test with a 16gig memory stick from Kingston and it worked fine.
I have formatted the stick as FAT and a cluster size of 64kbit I believe.
Maybe you can take a picture of you setup maybe I can spot something.
Regards Jordy.
As soon as I've got time a will create a guide on how to communicate with the vinculum thought the computer.
Maybe this can help to figure out what's wrong.
JohnCrow
Post by JohnCrow »
Hi Jordy
Don't think a photo would be very clear
I've got it connected as follows - Same device as you.
Module PIC
6 = C6 = TX
8 = C7 = RX
9 = C5 RTS
10 = C4 CTS
1 = 5V
7 = 0V
When it starts the leds on the module flash.
Before doing the mod to the flowchart regards setting flow control to off it didn't even show the start up message on the LCD.
Jordy101091
On powerup does the USB drive active led flashes together with the vinculum module.
hyperion007
Mine does not.
JohnCrow
Post by JohnCrow »
I've just tried mine again.Using a 256MB flash drive.
This is the sequence of events
Apply power to system
LEDs 1 & 2 on the Vinculum alternate a few times starting with 2
LED2 then gives a double flash
LED2 then lights steady and the led on the flash drive flickers.
Press SW0
LED on flash drive does not light when display says writing data though.
Jordy, could you please post the hex file created by your example.
That way will eliminate any problems that could be related to the bug described earlier.
Jordy101091
hyperion007 wrote:Mine does not.
So the LEDs on your flash drive does not flash when you first plug it in.
Jordy101091
JohnCrow wrote:Hi
Press SW0
Hi john can you verify that your are sending and receiving serial data with a scoop.
If this is not the case then you're flow control will be set enabled I think.
Also check if the rts and cts line are held low.
I will try my best to complete the tutorials on how to use the vinculum to communicate with the PC.
This should help you a bit to find any issues.
Regards Jordy
Ps. I have just read you're post, I'm not able to share the hex file now but when I get home I will post it.
JohnCrow
Post by JohnCrow »
Thanks Jordy
I'll get the scope out this afternoon and have a probe around.
Im getting data on the TX line, starts and stops with SW0/SW1
but just looks like noise on the RX line
RTS & CTS are low
