18f4523 RS232 wont compile
zadah
Has thanked: 3 times
Been thanked: 7 times
Post by zadah »
I have FC 6 version 6.0.4.0 installed
I get following error message while trying to compile my program to HEX ( I have only "RS232 receivestring component" in my test program)
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(402:5): error: unknown identifier 'tris'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(402:5): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(402:5): error: invalid operand 'tris'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(402:11): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(403:6): error: unknown identifier 'tris'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(403:6): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(403:6): error: invalid operand 'tris'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(403:12): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(403:34): error: unknown identifier 'port'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(403:34): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(403:34): error: invalid operand 'port'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(403:40): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(435:5): error: unknown identifier 'tris'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(435:5): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(435:5): error: invalid operand 'tris'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(435:11): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(436:5): error: unknown identifier 'tris'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(436:5): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(436:5): error: invalid operand 'tris'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(436:11): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(445:11): error: unknown identifier 'port'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(445:11): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(445:11): error: invalid operand 'port'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(445:17): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(445:10): error: invalid operand '(port) & (1 << ( (0)))'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(445:34): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(445:2): error: error in 'while' loop statement
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(515:4): error: unknown identifier 'port'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(515:4): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(515:4): error: invalid operand 'port'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(515:10): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(651:4): error: unknown identifier 'port'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(651:4): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(651:4): error: invalid operand 'port'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(651:10): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(796:5): error: unknown identifier 'tris'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(796:5): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(796:5): error: invalid operand 'tris'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(796:11): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(797:6): error: unknown identifier 'tris'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(797:6): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(797:6): error: invalid operand 'tris'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(797:12): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(797:34): error: unknown identifier 'port'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(797:34): error: failed to generate expression
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(797:34): error: invalid operand 'port'
C:\Program Files (x86)\Flowcode 6\CAL\PIC\PIC_CAL_UART.c(797:40): error: failed to generate expression
Test.c success
failure
Completed BoostC compilation, return = 1
zadah
Re: 18f4523 RS232 wont compile
Post by zadah »
OK
The problem was unconnected RTS/CTS pins in rs232 component... But I dont need those pins, could you fix this problem ?
If you switch off Flowcontrol then you shouldn't get these errors. If the errors come back then try switching Flow control on and back off.
Let me know if this problem keeps coming back and I will look into it for you.
zadah
Post by zadah »
Yes, that was the issue... Thanks
