how running target with Flowcode 4 and pickit3
HENOCH
Post by HENOCH »
I use Flowcode 4 with a pickit3 and the demoboard (18F45K20).
Programming the target from flowcode 4 it's ok.
But what i need to do for running the downloaded program ?
My code is in attachment.
thanks for your help
Clignotement diodes.fcf
this program blink all the led
(4 KiB) Downloaded 205 times
Re: how running target with Flowcode 4 and pickit3
Looking at your program the only thing I have spotted is that the extended CPU setting should be set to disabled.
What are your PICkit 3 settings? Is it the PICkit that's stopping the device from running? E.g. if you power the board and remove the PICKit then does it run correctly?
HENOCH
Post by HENOCH »
hello
you say : What are your PICkit 3 settings?
But Where can I see the pickit3 settings in Flowcode ?
