GLCD 128 x 128
Tony Brown
Has thanked: 36 times
Been thanked: 5 times
GLCD 128 x 128
Post by Tony Brown »
Anyone know of a GLCD 128 x 128 that can be used on flowcode 6?
The LMRD4265 that I have is clearly not compatible with flowcode 6 although thought that it would be.
Many thanks
Tony
Jordy101091
Has thanked: 25 times
Been thanked: 188 times
Re: GLCD 128 x 128
Post by Jordy101091 »
depends on what kind of controller IC this display has.
Tony Brown
Re: GLCD 128 x 128
Hi Jordy
This display uses the Toshiba 6963 driver ic.
Many thanks
Tony
Jordy101091
Re: GLCD 128 x 128
Hi Tony,
How good are you in C code.
Because I have made a component for the T6963C in flowcode but I cannot get it to work properly.
Maybe if you have some knowledge about C code you could help me get it to work.
Regards Jordy
Tony Brown
Re: GLCD 128 x 128
Hi Jordy
Unfortunately im more of an electronics person than coding, but I have attached a file that I found when I was looking for the driver previous, let me know if it is any good.
Tony
driver for T6963C.txt
(6.85 KiB) Downloaded 284 times
Tony Brown
Re: GLCD 128 x 128
Hi Jordy
Did you have any joy with that driver?
Tony
