I am assuming when I use a SLIDER on the simulator, and set the voltage +REF for the ADC reference that this is only for the simulator. In hardware will it be actual hardware voltage?
The simulator will only accept whole numbers. Hardware my +REF will be closer to 2.04, the simulator will only let me use 2.
Bob
ADC REF+ and Simulator
Re: ADC REF+ and Simulator
Hi Bob,
Which is the reason the default is 500 = 500 x 10 = 5000mV = 5V
So If vref on hardware is 2.04V then you will need to set vref at 204 = 204 x 10= 2040mv = 2.040V
yes that is correct.Bobw wrote:set the voltage +REF for the ADC reference that this is only for the simulator. In hardware will it be actual hardware voltage?
Vref in Flowcode is in millivolts x 10Bobw wrote:Hardware my +REF will be closer to 2.04, the simulator will only let me use 2.
Bobw
- Has thanked: 6 times
- Been thanked: 27 times
Martin,
Thanks....
That is kind of what I had thought. Going to use a couple of Pots and see if I can get +VREF somewhere near 2.048 volts to give me a 2 mv per step range on the ADC.
It works on paper and on the Sim.
I did notice on the properties the default is 500 I would have sworn it was only 5 when I first opened up the property's tab.
Too much staring at the screen and formulas on paper.
Thanks....
