how to convert a c variable into a flowcode variable
dirkvg@skynet.be
Flowcode V4 User
Post by dirkvg@skynet.be »
I start my flowcode program with a c block
unsigned int test=0;
test = test+1;
how can I use that variable in a calculation block?
in my attached file I hoped that on te LCD should come a 2 and not a 1
Thanks in advance for any help.
c_var_flowc_var.fcf
(5 KiB) Downloaded 456 times
Re: how to convert a c variable into a flowcode variable
If you look at the generated C code then you can see how the C variable is represented compared to the Flowcode variable.
    //C Code
    //C Code:
    unsigned int test =0;
    test=test+1;
    //Calculation
    //Calculation:
    //  test = test+1
    FCV_TEST = FCV_TEST + 1;
So I would get rid of this line.
And then change this line
test=test+1;
to this
dirkvg@skynet.be
Flowcode V4 User
Thanks for your answer but the result is not still good
If you look at my attached program, after the simulation of that program on the LCD comes a 1
and for me it must be a 2
c_var_flowc_var1.fcf
(5 KiB) Downloaded 441 times
dazz
Has thanked: 474 times
Been thanked: 458 times
Post by dazz »
The result is what you are asking for as your variable is 0 so test =test+1 will equal 1, is there any specific reason you are using a c block in your code ??
Dazz
C code will not simulate which is why you are getting 1 instead of 2. Also I would initialise the value before incrementing, in simulation it will initialise to 0 for you but the hardware will not do this and will be random at best.
dirkvg@skynet.be
Flowcode V4 User
Thanks to all for the answers
