16f1939 of ADC Is not correct! SOS!!!
nnnnff
Has thanked: 3 times
Been thanked: 6 times
Post by nnnnff »
As shown in example, there is no question of simulation in the FLOWCODE V4, downloaded to the chip after 16f1939 hardware, however, can only display 1.2;2.4;3.7;0. Can't continuous transformation, I again in the proteus simulation, is also the same problem!What reason is this?Please help me!!!!!!!Thank you very much!
16f1939.rar
(181.27 KiB) Downloaded 476 times
Re: 16f1939 of ADC Is not correct! SOS!!!
Hi nnnnff,
Can you make a backup copy and replace:
PIC_ADC_18.c thats in
C:\Program Files (x86)\Matrix Multimedia\Flowcode V4\Components (If 64 bit windows)
or
C:\Program Files\Matrix Multimedia\Flowcode V4\Components (If 32 bit windows.)
With the attached file.
I have not had time to properly investigate so the attached file in not a real fix, more like a bit of a bodge!
Hope it works for you.
If I get more Time I will see if I can find out what is causing the issue
PIC_ADC_18.c
(8.78 KiB) Downloaded 545 times
nnnnff
Post by nnnnff »
No problem.
Did it work?
Not got a 16F1939 to test with.
