Flowcode V5 import fails
keesp
Post by keesp »
I am trying to import an fcf file from Flowcode 5 in Flowcode 6, but this fails with an error message saying the file is corrupt. Any ideas what could be wrong?
thanks
Kees
Timer 48uur LCD display lus naar 0.fcf
(51.69 KiB) Downloaded 234 times
DavidA
Has thanked: 58 times
Been thanked: 258 times
Re: Flowcode V5 import fails
Post by DavidA »
I cannot seem to open this in V5 either.
Can you confirm what version of v5 you are running (Help >> About) and that it loads correctly on your version of Flowcode v5.
keesp
Post by keesp »
Sorry for the delay, but I needed to ask my student. The version is:
Flowcode 5 professional version v5.5.2.1 (30-01-2013)
Cheers
Kees
DavidA
Post by DavidA »
What language is the computer used in and what language is Flowcode used in?
As i cannot open it in v5 even i am assuming that maybe there is a character which Flowcode does not like opening in the variable names/macro names etc.
keesp
Post by keesp »
Hi David,
the set language is Dutch. But my Flowcode 6 is also set for Dutch
Cheers
kees
Does the back-up version open?
if you rename the file which ends in .001 from:
Timer 48uur LCD display lus naar 0.fcf.001
To
Timer 48uur LCD display lus naar 0.fcf then the back-up file may open?
All flowcharts should automatically generate a file ending in 001 which is a back-up Flowchart.
keesp
Post by keesp »
it doesn't get to that point...no backup file is made because Flowcode crashes...
keesp wrote:no backup file is made because Flowcode crashes...
i was thinking that when the flowchart was originally made, it produced a back-up?
I know it won't now it crashes.
But if there never was a backup from the start then, I cant really suggest anything else.
Sorry
DavidA
Post by DavidA »
Can you check that the variables/macros within the program do not use any special characters (eg: Ü, ó, ¿ etc)
DAvid
