Installation problem
STibor
Has thanked: 116 times
Been thanked: 113 times
Post by STibor »
I downloaded the V6.0.9 Flowcode program, but no installs.
Error message:
"The installation package could not be opened. Contact the application vendor to verify that this is a valid Windows Installer package to package." Win XP SP3 operating system.
stewartbaker
Been thanked: 18 times
Re: Installation problem
Post by stewartbaker »
Same here...
S.
Hi Guys,
It may that you downloaded at bit too soon from when it was first started to be uploaded.
I did the update at 1820 and have had no problems with downloading or installing:
(186.34 KiB) Downloaded 3649 times
My windows version is 64bit win 7.
Perhaps you can check for updates again, and download the new version.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
Could you check the file length? It should be 195364484 bytes. If the file is smaller you probably downloaded it while it had not yet been fully uploaded.
― C.S. Lewis
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Post by JohnCrow »
I confer what Martin has posted, I've just downloaded and it installed all ok.
Sounds like it hadn't finished uploading.
saakis
Has thanked: 8 times
Been thanked: 3 times
Post by saakis »
Good morning Matrix people! Doing update to version 9 and 10 last night, I lost my lisences and from prof use I now have home edition. Finally it was downgrade... Is there any soloution to that?
Sakis
kersing
Post by kersing »
Hi Sakis,
After installing the update, did you try to activate (again)? That should solve your problem.
Best regards,
Jac
― C.S. Lewis
saakis
Post by saakis »
Hi Jac!
I tryied but I don't have the activation passwords only the purschacing password and when I try to create a new one it says that this pwd has consumed.
Sakis
kersing
Post by kersing »
Hi Sakis,
You should have a user name and password that enables you to log on to http://www.flowcode.co.uk/accounts/login.php. That combination is required for activation.
Best regards,
Jac
― C.S. Lewis
saakis
Post by saakis »
It works! I feel stupid... :(
Thank you Jac!!!
