Just received a pair of these boards.
Both setup the USB driver under windows 7x64 ok
But I'm getting slightly strange behaviour from them.
When I program them in FC, the file is sent to the device ok.
But after the file sent message, FC starts to show a continues row of .........
Pressing cancel gives the error 255.
The program sent to the device will start running after pressing the reset button.
Unplugging and reconnecting the USB, the program will start running in about 4 seconds
If I try programming directly in mLoader The green Icon shows Student. (I assume this is to do with the firmware in the PIC.
Again they will both program and erase ok in mloader
I'm using the mLoader exe file David sent last week, though I get the same results with the one included in FC6.0.9
HP1110/HP4829
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Re: HP1110/HP4829
Hi John,
Thanks for that ill look into it, it may be due to a similar bug with the ECIO ARM and devices which "time out" in programming mode.
