any chances of creating a component for 2.2" 320X240 SPI ILI9341 glcd ? I have the datasheet and codes (attached), but not enough knowledge to create one myself. I believe that many Flowcode users would highly appreciate it.
With best regards,
GLCD with ILI9341
Forum rules
GLCD with ILI9341
- 2.2TFT320x240_Display.rar
- Display data and codes
- (3.83 MiB) Downloaded 681 times
hyperion007
- Has thanked: 49 times
- Been thanked: 101 times
Re: GLCD with ILI9341
This falls under the UTFT request I posted long ago: http://www.flowcode.co.uk/mmforums/viewt ... 56&t=14170
Here is a post on another forum about this display and the UTFT library: http://forum.pjrc.com/threads/25579-UTF ... CD-Display
Yes I saw it, but believe that it is a lot of work (maybe I'm wrong). Maybe this will be easier to do because I provided datasheet and codes and there are arduino codes for ILI9340 & ILI9341 too, which I believe can be modified in relatively short time. There are many small 2.2" LCD's with these two chips with excellent price/quality ratio and they could be interesting to many. So, maybe...
Can I use Arial or Times New Roman font in this display? Or other font? regards.
Here is information on how the Font is drawn.
viewtopic.php?f=7&t=16917&p=70360&hilit ... ont#p70337
And here you can find how to change the font in Flowcode 6.
viewtopic.php?f=54&t=16703&p=69140&hili ... ont#p69140
You could also draw the font you want from a bitmap if the content is fixed. Either streamed from an sd card or in v7 there is a new component to place a bitmap into rom and draw from there.
