I have problem with component Motor (Full Bridge) during simulating in Flowcode V6:
simply simulation work first time ok than i stop simulation, restart it and component now don't work;
if i close Flowcode and restart it work also first time and then not.
My system is Windows 8.1 64 bit.
Problem with component Motor (Full Bridge)
ITISVARESE
- Has thanked: 9 times
- Been thanked: 3 times
Re: Problem with component Motor (Full Bridge)
Hi All,
Apologies for this having taken so long, but I think we have got to the bottom of this problem now. Seems that the motor was only able to start when the pin changed, but not if the pin was already turned on at the start of simulation.
Fixed versions of the motors will be provided in the next maintenance patch - but in the mean-time, you may use the components in this .zip file...
Simply extract the .fcfx files from the .zip, and copy them over the ones in the components folder of your FC6 install.
All the best,
Steve.
All the best,
Steve.
ITISVARESE
