Glcd (ks0108) printing new line and earesing old line.
Jordy101091
Has thanked: 25 times
Been thanked: 188 times
Post by Jordy101091 »
Hi all,
I have a question and I can't seem to figure out how to approach this problem.
I'm working on a analog clock type display. I have figured out how to print the clock handles and such.
They are moving as well but I don't know how to delete the previous printed pixels.
Without clearing the whole screen.
I have tried to change the foreground color in flowcode to print the same line in white pixels.
But doesn't seem to work in simulation.
Or doesn't this option show up in simulation mode.
Let me know what you all think.
Regards jordy
STibor
Has thanked: 116 times
Been thanked: 113 times
Re: Glcd (ks0108) printing new line and earesing old line.
Post by STibor »
Hi!
Draw a sketch of the previous background color.
draw_clear.fcfx
(8.67 KiB) Downloaded 314 times
dazz
Has thanked: 474 times
Been thanked: 458 times
Post by dazz »
Hi Jordy
I've read a post from Benj on the forum (cant find it now), where from memory he says to simply blank out the pixels you just wrote, then send the next set of pixels,i assume your clock gave will be fixed so try resending the last hand update using the background colour, then send the next hand pos etc
print hand in foreground colour
delay
resend last print hand in background colour etc
hope it helps
Dazz
For an analogue clock something like this should work well.
Loop Start
Clear Hour Hand - Draw previous hour position in BG colour
Clear Minute Hand - Draw previous min position in BG colour
Draw current Minute hand - Draw current min position in FG colour
Draw current Hour hand - Draw current hour position in FG colour
update prev values with current values
Small delay, maybe calculate all your current angles here to speed up draw times.
Loop End
If you use a timer interrupt in the background to measure the passing of time and update your sec, min and hour variables then it should all work nicely.
