I tried using a previously successful working program created with Flowcode V5 which used I2C and HP488 to communicate with CMPSO3 compass module.
When I tried loading and compiling to chip the same program using Flowcode V6 it doesn't work.
Any ideas for a fix.
Thanks Gary
Flowcode V6 Ic2
- Has thanked: 7 times
- Been thanked: 4 times
Re: Flowcode V6 Ic2
HI
What i do is import it into V6, then i simply replace the components with the V6 ones
Dazz
Dazz
Re: Flowcode V6 Ic2
Hi Gary,
If you post your program then we can have a quick look and see if there is anything obvious we can suggest to quickly try.
Without the program we are basically guessing what might have gone wrong.
Re: Flowcode V6 Ic2
Hi Benj
Have attached program to look at.
Thanks Gary
Thanks Gary
- Working16bit_v6.fcfx
- (11.1 KiB) Downloaded 256 times
Re: Flowcode V6 Ic2
Hi Gary,
If you select the I2C component on the panel then look at the properties pane and you should see that the Channel property is currently unselected.
Assign a value to this and hopefully the program should compile and spring to life on your hardware.
Let us know how you get on.
Re: Flowcode V6 Ic2
Hi Benj
I tried the channel advice but didn't work, so out of desparation / Inspiration I added another Restart after label "Send Module Addr Read" and it now works.
I don't understand why the V5 version worked but not V6, but it works so happy days.
Thanks Gary
Thanks Gary
