FC6.1 Using List occurrences.
When loaded flowchart from here
When selected Previous_x or Previous_y for example then select List occurrences, the result window is blank even though there are several occurrences of both variables.
Re: FC6.1 Using List occurrences.
Thanks Martin,
Now on the official list to investigate.
Thanks Ben,
I believe know what's causing the issue.
If a variable is created e.g
Previous_x
Then if the case is changed when assigning a variable e.g
previous_x = 5
The variables with a different case will no be included within Find Results.
