RFID ICODE FLOWCODE 6.1 avr
coffy
Been thanked: 3 times
Post by coffy »
FLOWCODE AVR 4 program works very well with atmega324p (icode).
Flowcode 6.1 AVR bug routines for reading and writing blocks (icode) :evil: , can you solve this problem
thank you.
BRUNO
Re: RFID ICODE FLOWCODE 6.1 avr
Hello Bruno,
Please can you post a program that demonstrates the problem and we will look into it for you.
coffy
Post by coffy »
ok,
the same file flowcode 4 works very well on my cards,
program card reading icode
http://tsin.langevin-la-seyne.fr/SIN/se ... -rfid.html
bruno
UID.fcfx
(8.93 KiB) Downloaded 329 times
Has thanked: 481 times
Been thanked: 699 times
I notice that you are printing the contents of 4 bytes of the card as a string.
Do you have a null terminated string already programmed into the card?
What results are you getting (versus what you expect) with this program?
(e.g. what does it display? what status LEDs do you get on Port B?)
coffy
Post by coffy »
hi,
I wrote "2012" in Section 5 with flowcode 4 on the card icode
when reading I do not have 134(0x86) on port B
icode each card gives me a different status code (never 134(0x86)), the macro blocks reading does not work.
in flowcode 4 avr with the same program I read "2012" without problem, flowcode 6 is bugged in Avr :evil:
bruno
Have you got CTS pin connected?
What status LEDs do you get when a card is present?
We''ll try and repeat your tests with an AVR setup.
coffy
Post by coffy »
HI,
Getrfiduid-> port b: 134 ok.
ReadRFIDBlock (5,0)-> port b : not 134 ( not ok ).
No wiring problem (cts) for works with flowcode 4 avr
bruno
Hi Bruno,
Thanks for the bug report.
Turned out to be a receiver timeout bug in the AVR CAL UART code (due to compiler optimisations).
But in the process of resolving the issue I made some improvements to the RFID component too.
Both updates attached.
Thanks and regards,
Leigh
RFID.fcpx
(11.45 KiB) Downloaded 324 times
AVR_CAL_UART.c
(58.89 KiB) Downloaded 324 times
coffy
Post by coffy »
hi,
ok, I just tested and now it works very well. :D :D
thank you
bruno
