Flowcode 6.1.1.0 released
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
For those that missed last weeks Matrix newsletter announcing the next update would be released this week (as well as for those that did read it but do not want to check for updates all the time), the update is life. Use 'Check for Updates' in the 'Help' menu to get it if Flowcode does not pop up a notification...
The release notes are in "C:\Program Files (x86)\Flowcode 6\logs\changes.txt" after installation of the update.
― C.S. Lewis
Rudi
Has thanked: 493 times
Been thanked: 187 times
Re: Flowcode 6.1.1.0 released
Post by Rudi »
solved
hi
thank you for info.
do someone know the direct link, i can not go on with my pc to internet ;-(
i have try:
http://www.matrixtsl.com/accounts/files ... _Setup.msi
best wishes
thanks
rudi ;-)
Hi Rudi,
I could not get the link to work in IE, so tried chrome and Flowcode update downloaded ok,
I have pm'd you the link.
Flowcode update downloads with chrome OK.
Rudi
Post by Rudi »
Hi Guys
again ;-)
( copy pasted ) ;-)
i
-download it,
-install it (XPSp3),
-run it ( without need again register ) ,
-all template are availabel
and i am happy first time.
very tidy.
very stable
very welcoming to the next new microcontroller experiment
but now 'again' ;-)
i will test all asap and next times and will let you know how the second time is
but i am sure - you go on in perfection in FLOWCODE, now.
Again Great Work MM Staff !!! Thank you!!!
Best wishes
rudi ;-)
edit: March 27, 2015
New Install in Windows 7 at new PC
´Same Procedure, same Key, same Datas,
HomeVersion, no Chip Pack active
Steve001
Has thanked: 460 times
Been thanked: 523 times
Post by Steve001 »
Can I ask why the flowcode updates are so large ? (current update 206 Meg)
looks like we are downloading the entire program again ?
is it not possible to make the installer update the relevant files ?
I am on a 8mb Connection and because of an inadequate infrastructure on the behalf of bt and a congested local telephone exchange I am lucky on a weekend to get 1 meg ! due to " Bandwidth throttling etc .." my isp say's they cannot do anything about it unless I go fibre ... err no ££££
it is very annoying when you have massive updates .
Sorry for the rant
PS. Martin I am Downloading In I.E 11 Ok for me
Hi Steve,
Steve001 wrote:PS. Martin I am Downloading In I.E 11 Ok for me
Just tried again an it does not download.
If it does for you then it must a specific issue with my IE11 and PC.
Hi Steve,
We did create a patch for 6.1.1.0 however there were problems with it which meant at the last minute it was pulled. A lot of our recent efforts have gone into the installation and patching system to make it more robust and easier to roll out so the fact it didn't work is little annoying. However going forward hopefully we will be able to bring back patching.
Steve001
Post by Steve001 »
Hi Benj,
Apologies for the rant Thanks for that it get really annoying at times as my internet speeds are out of my hands . Have had the official line of the cabling in our estate in in aluminium and approximately 40 years old and it's in BT hands .... :roll:
I did manage to download update although it did take a long time
Hi steve, I can imagine it did.
At lease we are not on 56k dial up anymore.
Thank goodness.
Rudi
Post by Rudi »
I bought new PC with Windows 7 64 Bit.
I try to install FC 6.1.1 ( 22.01.2015 )
My FC Version is fall to HomeVersion
I take the same Userdata, Activation Key and Licenze Key like in WIN XP ( succesfull as Prof Version )
I have deaktivate
- G Data Firewall is off
- Windows Defender is off
- Windows Firewall is off
No Warning Message comes.
FC tell :
Your Key has been accepted....
Please close and restart Flowcode....
my Username is showing in Window "Show Licenzes"
but all packs are inaktive
after restart, same.
now, the problems are start from scratch again?
It is always very annoying and costly to come across the same old problems.
The dependence on the forum annoying if I'm honest.
Dear Matrix tsl!
A complete uninstall is no uninstall.
After re-installing my data is still displayed.
Why are not all RegKeys adjusted after uninstalling?
Why is it to register the product properly so complicated?
It always fails at the simplest things.
My Regkey and Data 're okay, even FC announces successful registration. But anyway Home version. No ChipPack active. And I can not compile a single project.
"You are not authorized. "
Thank you for this unhappy weekend now!
edit
Workaround:
After Install FC and register and shows HOMEVERSION without activated Chip Packs,
copy from succesfull registered FC version ( Professional ) the !important! basic.key ( install folder Flowcode \licenses ) from your "Windows XP" Install to the Windows 7 (x86) install folder.
Restart Flowcode and have phun.
Please MM!
Work at this crazzy Registry / "Armadillo Engine"
rudi
headhuntergr
Has thanked: 34 times
Been thanked: 5 times
Post by headhuntergr »
Hello!
I upgraded today and i got this.
Is that correct?
kersing
Post by kersing »
No, that is an older version that was accidentally placed on-line. That issue should be solved now.
If you log in to your account (here) you should be able to download the Flowcode 6.1.1.0 installer.
― C.S. Lewis
