MULTITASKING WITH FLOWCODE
bigman
Post by bigman »
Hi everybody;
I am interested in developping multitasking applications with FLOWCODE V5.
Is there anyone who has some ideas on how to develop multitasking applications with FLOWCODE?
Thank you for your help!
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: MULTITASKING WITH FLOWCODE
Post by kersing »
Please register for the Flowcode 5 forum if you want help with FC5. See the link in my signature for instructions.
― C.S. Lewis
A lot of "multitasking" or "real time" processing is done using hardware timers. You basically use the timer to switch between different macros so it appears that the macros are running in parallel. This is often referred to as a round robin approach.
The timer interrupt macro could simply increment a variable named Mode. If mode is greater than say 3 then reset to 0.
In the main routine you could have a switch case icon based on the value of the Mode variable.
If it is 0 then you monitor a keypad for input.
If it is 1 then you output any keypad inputs to a LCD
If it is 2 then you switch outputs on and off based on the keypad inputs
If it is 3 then you flash an LED based on the keypad inputs
