measuring voltage program
FMGA
Has thanked: 1 time
Post by FMGA »
hello ,
i'm in a school project and i need to measuring a voltage througt a card with a flowcode program,
i'm in mess with it , i don't now how to work , some idea ?
work on fowcode V5 actually (and im an original french, sorry)
please help :?
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: measuring voltage program
Post by QMESAR »
FMGA wrote: i'm in a school project and i need to measuring a voltage througt a card with a flowcode program,
What Card ?? are you talking about ,we can not help you if you do not tell us what hardware you are using ,
post your project and we can try to help you :D
FMGA
Has thanked: 1 time
Post by FMGA »
its a homemade card from my professor
she make a connection of a matrix PIC to a battery charged by a solar panel , and i need to put the caractericts of the battery ( voltage ect) on a lcd of the PIC 16F877A .
This example should hopefully help to get you up and running.
Displaying Voltage.fcf
(9 KiB) Downloaded 575 times
FMGA
Has thanked: 1 time
Post by FMGA »
thanks Benj , i will work on it :D
FMGA
Has thanked: 1 time
Post by FMGA »
Hi guys
so i come back from holiday, and i take a look of the exemple from Benj
i'm ok with the voltage but i read back the instruction of the professor and it will be a bit more complicated :roll:
i give u an extract of :
" Converter and distributor of energy " 1-Role and description of the block
This block allows to load the battery, to feed the various functions and to supply certain sizes measured to the block " micro-programmed system ".
It realizes the transfer of energy between the photovoltaic panel, the load and the battery.
It measures:
-the tension and the current of entrance so that the microcontroller can determine the optimal point of power of the generator voltaic photo (Ve, Ie).
-the tension and the current of exit of the converter (Vs, Is).
-the current feeding all the electronic boards of the system (running in the load (Ic).
The current circulating in the battery (Ibat) will be calculated by the microcontroller from the moderate currents previously. "
sorry for the possible bad translation , don't hesitate to ask me :)
thanks in advance :D
FMGA
Has thanked: 1 time
Post by FMGA »
Up ? :mrgreen:
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
While we can help with specific questions and point in the right direction, we are not going to provide complete solutions for schoolwork. Exercises in schoolwork are created for students to solve... Is there something specific we can answer??? Do you have any ideas you want us to provide feedback on?
― C.S. Lewis
FMGA
Has thanked: 1 time
Post by FMGA »
I understand that , i don't ask a file completed , but i'm not comfortable with flowcode, so i didn't take up the projet in a good way :mrgreen:
