Problem sending SMS via GSM EB066-01
simsto
Flowcode V4 User
Has thanked: 3 times
Post by simsto »
I have some problems sending SMS via the GSM EB066-01-Module.
I am using Flowcode v4.5.18.74. The used chip is a 18F4455. The oscillator frequency is 4 MHz.
The board is correctly connecting to the network. I can call the board and the return value 2 is given for an incoming call. But there is no value 1 for incoming sms. Otherwise I am not able to send SMS. Calling the macro leads to a return value 255.
I have attached my testfile.
Could you please give me a hint?
Best regards
Simon Stockhorst
Flowcode1.fcf
(6 KiB) Downloaded 646 times
Re: Problem sending SMS via GSM EB066-01
Hello Simon,
My advice would be to perform a 1 second flasher test as I'm not sure if your configuration settings are correct. This should help to confirm if your serial baud rates are also correct.
http://www.matrixtsl.com/wiki/index.php ... ED_flasher
simsto
Flowcode V4 User
Post by simsto »
Hello Ben,
I tested the led flasher and everything works fine. I use several e-blocks with serial communication like (rfid EB052, gps eb056, tft with touchscreen EB076) connected to Port C and got them working. I wonder why a call is recognized and SMS not.
Could it be a problem with our prepaid card? I got the board working with another card three years ago. http://www.matrixtsl.com/mmforums/viewt ... b1124101f4
Thanks in advance.
