pwm of atmega16 not compile
nnnnff
Has thanked: 3 times
Been thanked: 6 times
Post by nnnnff »
pwm of atmega16 not compile.why? for help!thank!
atmega16_pwm.fcf_avr
(6.5 KiB) Downloaded 577 times
E:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c: In function 'FC_CAL_PWM_Set_Duty_10Bit_1':
E:\Program Files\Flowcode(AVR)\v5\CAL\/AVR\AVR_CAL_PWM.c:1121: error: 'OCR0A' undeclared (first use in this function)
Return code = 1
FINISHED
Re: pwm of atmega16 not compile
Hi nnnnff,
Can you back up a copy of your original ATMEGA16.fcd
I have modified ATMEGA16.fcd for you to try.
Can you place it in your fcd folder below is the path depending on if you have a 32 or 64 bit operating system
C:\Program Files (x86)\Flowcode(AVR)\v5\FCD\
C:\Program Files\Flowcode(AVR)\v5\FCD\
You will need to restart flowcode after replacing modified file
ATMEGA16.fcd
(10.1 KiB) Downloaded 473 times
nnnnff
Post by nnnnff »
thank!compile!
But the simulation is not correct in proteus!
for help!
atmega16_pwm.rar
a
(12.35 KiB) Downloaded 550 times
Hi nnnnff ,
I can't comment about proteus as its very pricey so cant test with that.
But you need to take in account if project does not work within external simulator. then the issues could be either simulator or flowcode.
Should blame flowcode straight away.
I have just looked at your flowchart and you have got SetDutyCycle d
but you have not got anyway of setting d,
E.g analogue component.
So will only be assigned a random value.
Of course when its corrected there is still no guarantee all will work.
The only way of knowing is with actual hardware.
