How to suppress unwanted compiler/linker warning messages?
gtc
Has thanked: 30 times
Been thanked: 15 times
Post by gtc »
How can I suppress the generation of these numerous 'unreferenced functions removed' warning messages from the BoostC compiler/linker. I really don't need to know any of this:
Warning unreferenced functions removed:
FC_CAL_Port_In__x in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_IO.c
FC_CAL_Port_Out__x in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_IO.c
FC_CAL_Port_Out_DDR__x in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_IO.c
Wdt_Delay_S in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_Delay.c
Wdt_Delay_Ms in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_Delay.c
FCI_DELAYINT_US in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_Delay.c
FCI_DELAYINT_MS in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_Delay.c
FCI_DELAYINTWDT_MS in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_Delay.c
FCI_DELAYINT_S in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_Delay.c
FCI_DELAYINTWDT_S in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_Delay.c
FCI_GETCHAR in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_GETLENGTH in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_MIDSTRING in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_LEFTSTRING in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_RIGHTSTRING in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_TOSTRING in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_TOSTRS16 in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_TOSTRS32 in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_TOSTRU16 in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_TOSTRU32 in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_TOLOWER in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_TOUPPER in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_COMPARE in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_FLOAT_TO_STRING in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_NUMBER_TO_HEX in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_STRING_TO_INT in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_STRING_TO_FLOAT in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_STRREV in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_STRMOV in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_SHEAD in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
FCI_SCOPY in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_String.c
isinf in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_Float.c
pow in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_Float.c
flt_round in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_Float.c
flt_floor in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_Float.c
flt_ceil in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_Float.c
flt_atan in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_Float.c
cos in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_Float.c
sin in: C:\Program Files\Flowcode 6\CAL\PIC\PIC_CAL_Float.c
FCM_GetMode in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCM_DrainTimerOn in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05266_switch_base__ReadState in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05266_switch_base__WaitUntilHigh in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05266_switch_base__WaitUntilLow in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05265_switch_base__ReadState in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05265_switch_base__WaitUntilHigh in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05265_switch_base__WaitUntilLow in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05264_switch_base__ReadState in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05264_switch_base__WaitUntilHigh in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05264_switch_base__WaitUntilLow in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_03d94_led_base__TurnOn in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_03d94_led_base__TurnOff in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05263_switch_base__ReadState in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05263_switch_base__WaitUntilHigh in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05263_switch_base__WaitUntilLow in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_03d93_led_base__TurnOn in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_03d93_led_base__TurnOff in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_03d92_led_base__TurnOn in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_03d92_led_base__TurnOff in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_03d91_led_base__TurnOn in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_03d91_led_base__TurnOff in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05262_switch_base__ReadState in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05262_switch_base__WaitUntilHigh in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05262_switch_base__WaitUntilLow in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05261_switch_base1__ReadState in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05261_switch_base1__WaitUntilHigh in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05261_switch_base1__WaitUntilLow in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_0526a_switch_base__ReadState in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_0526a_switch_base__WaitUntilHigh in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_0526a_switch_base__WaitUntilLow in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05269_switch_base__ReadState in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05269_switch_base__WaitUntilHigh in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05269_switch_base__WaitUntilLow in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05268_switch_base__ReadState in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05268_switch_base__WaitUntilHigh in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05268_switch_base__WaitUntilLow in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05267_switch_base__ReadState in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05267_switch_base__WaitUntilHigh in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_05267_switch_base__WaitUntilLow in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_08251_switch_array1__ReadState in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_08251_switch_array1__WaitUntilHigh in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_08251_switch_array1__ReadAll in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
FCD_08251_switch_array1__WaitUntilLow in: C:\DOCUME~1\Test\MYDOCU~1\Flowcode\Timer Test 1.c
Re: How to suppress unwanted compiler/linker warning message
There is a way of disabling warnings for the compile stage but there doesn't seem to be a way for the link stage. It is the link stage that spits out the unreferenced function warnings.
gtc
Post by gtc »
Any chance of getting Source Boost Technologies to provide a means?
