LCD Greek symbols
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
LCD Greek symbols
Post by Jan Lichtenbelt »
Is there an easy way to send the Greek symbol Ω to a LCD?
cubitus54
Flowcode v5 User
Has thanked: 7 times
Been thanked: 32 times
Re: LCD Greek symbols
Post by cubitus54 »
We need a 5x8 matrix encoded
exemple : http://www.instructables.com/id/LED-Sco ... enerator-/
this is "é"
Flowcode V6.1.2.0(11 05 2015)
Jan Lichtenbelt
Hi Cubitus,
Thanks.
In the datasheet op de LCD block I found the value of 0xF4 for the omega symbol. But how can I use that in flowocode?
Kind regards
Jan
Hi Jan,
Have you tried PrintASCII 0xF4?
Jan Lichtenbelt
IT WORKS!
Jan Lichtenbelt
How do I add greek symbols to a string?
Kind regards
Jan Lichtenbelt
Hello Jan,
You can add the character to the string like this.
strvar[x] = 0xf4
where x is the location in the string you want to add the symbol.
Or you can simply type in the string and at the point you want to insert the symbol hold down the Alt key and type the number 244 on the numeric keypad on your keyboard and then release the Alt key. You should get something looking like this.
String = "Test¶"
This method does not work for the numeric digits above the letters on the keyboard, just the numeric keypad.
Lastly you can use the Alt key method to assign the symbol to the location in the string array if you don't want to have to remember the hex value,
strvar[x] = '¶'
I use Alt + 248 a lot for good old °C
Has thanked: 481 times
Been thanked: 699 times
Another way is ...
mystring = "Omega=\xf4"
