How to play Audio files using Flowcode V & Arduino
mikey89ryan
Has thanked: 1 time
Post by mikey89ryan »
My name is Michael. I am in the 3rd year of college studying Automation and robotic systems as a mature student. I am building an Automated model drawbridge for my final year project.
I wish to have an audible alarm sound before my drawbridge operates so I purchased a DF player and a SD card to integrate with my Arduino. I am using Flowcode V to programme the whole thing.
I cannot find any info or an example as to how to play an audio file using flowcode V. I am wondering does anybody know anyplace I could find afew examples or tutorials or somebody that has been successful in doing the same using an Arduino and Flowcode V.
Any help would be Grrreat!!!
Thank you!
acestu
Has thanked: 783 times
Been thanked: 223 times
Re: How to play Audio files using Flowcode V & Arduino
Post by acestu »
Hi Michael,
Welcome to the Flowcode forums, can you post the data sheet for your DF player, and any info that you have, this will enable us to help you further.
Stuart
mikey89ryan
Has thanked: 1 time
Hi Stuart.
This is all the info I could find.
•Supported sampling rates (kHz): 8/11.025/12/16/22.05/24/32/44.1/48
•24 -bit DAC output, support for dynamic range 90dB , SNR support 85dB
•Fully supports FAT16 , FAT32 file system, maximum support 32G of the TF card, support 32G of U disk, 64M bytes NORFLASH
•A variety of control modes, I/O control mode, serial mode, AD button control mode
•Advertising sound waiting function, the music can be suspended. when advertising is over in the music continue to play
•Audio data sorted by folder, supports up to 100 folders, every folder can hold up to 255 songs
•30 level adjustable volume, 6 -level EQ adjustable[attachment=0]PlayerMini_EN.png
(97.87 KiB) Downloaded 13154 times
(64.26 KiB) Downloaded 13154 times
acestu
Post by acestu »
Hi Mikey,
These commands are on the same page as your diagram:
(33.49 KiB) Downloaded 13130 times
(27.53 KiB) Downloaded 13130 times
So if you know how to connect it, its just a case of sending it serial commands from your Flowcode chart.
cheers
Stuart
acestu
Post by acestu »
Hi Mikey,
I have just found the datasheet by searching on google:
DFPLAYER_MINI.PDF
(1.14 MiB) Downloaded 959 times
cheers
Stuart
mikey89ryan
Has thanked: 1 time
Thanks all. I will have a look at this at a later time. The exams are nearly here so iv had to put away the project until the xmas.
I will update as soon as I can.
Thank you for your help!!!
mikey89ryan
Has thanked: 1 time
Hey Stuart.
When I am sending serial commands to the chip have I to call a component on the flowcode menu like the FAT or the MIDI. Or am I sending it as an output to the RX or TX pins. Then which one?.
Mike
acestu
Post by acestu »
Hi Mikey,
Use the rs232 component in the comms menu to send and receive your serial commands.
Stuart
mikey89ryan
Has thanked: 1 time
Hey Stuart
was having a play around with it today and no luck yet. it has to be my programming. :o . So I followed the manual and used the serial code it gives in the 2nd example as that's how I have the audio file saved on the SD card. Folder is called 01 and the file is named 001.mp3
(40.5 KiB) Downloaded 12172 times
I used exactly these serial commands and then did the following on flowcode. It doesn't include the last 4 serial commands in my picture as I couldn't fit them in but its as it is in the example
What do you think?
Also does it matter what kind of speaker I use. I was using a 32 watt that came from a 230v set?. I'm abit confused when it comes to speakers
(18.12 KiB) Downloaded 12172 times
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
1) Looking at the snippets of the documentation in your message you are only specifying the file, should you not issue a play command as well?
2) The documentation lists FF between 7E and 06 and your code seems to be missing it.
3) What values are you sending in the last three bytes?
4) If your flowchart is too large to fit in the screen shot you can attach it to the message so we can see all of the code.
― C.S. Lewis
mikey89ryan
Has thanked: 1 time
The last four serial commands
(18.52 KiB) Downloaded 12163 times
this might help also
(32.21 KiB) Downloaded 12163 times
kersing
Post by kersing »
Should the last byte not be 0xEF?
― C.S. Lewis
mikey89ryan
Has thanked: 1 time
yes you are correct. I made a couple of errors in it I have fixed them but still nothing
acestu
Post by acestu »
Hi Mikey,
Can you post the Flowcode file that you have and then someone can have a look at it for you.
cheers
Stuart
hiromiyureei
Post by hiromiyureei »
Hello to everybody I'm trying to program the same df player but without results is certainly a programming error you have found a solution thanks to all
Bachman
Has thanked: 9 times
Been thanked: 53 times
Post by Bachman »
What is the problem exactly? You have to send 9 bytes to control the player. Here is some example:
Play: 7e,ff,06,0d,00,00,00,fe,ee,ef
Pause: 7e,ff,06,0e,00,00,00,fe,ed,ef
Stop: 7e,ff,06,11,00,00,00,fe,ea,ef
Next: 7e,ff,06,01,00,00,00,fe,fa,ef
Previous: 7e,ff,06,02,00,00,00,fe,f9,ef
Play first file: 7e,ff,06,03,00,00,01,fe,f7,ef
Volume 1/30: 7e,ff,06,06,00,00,01,fe,f4,ef
Volume 5/30: 7e,ff,06,06,00,00,05,fe,f0,ef
Volume 10/30: 7e,ff,06,06,00,00,0a,fe,eb,ef
// 7E FF 06 0F 00 01 01 xx xx EF
// 0 -> 7E is start code
// 1 -> FF is version
// 2 -> 06 is length
// 3 -> 0F is command
// 4 -> 00 is no receive
// 5~6 -> 01 01 is argument
// 7~8 -> checksum = 0 - ( FF+06+0F+00+01+01 )
// 9 -> EF is end code
