Rotate left
- Jan Lichtenbelt
- Has thanked: 128 times
- Been thanked: 264 times
Re: Rotate left
Hi Jan,
By rotate do you mean shift or do you need the bits to wrap around?
Here is some code to shift.
If you want to shift and wrap then you will likely have to do something like this.
Or to go the other way.
var = var >> 1;Code: Select all
count = 0;
while (count < shiftcount)
bitsave = var & 0x01;
var = var >> 1;
if (bitsave == 0x01)
var = var | 0x80;
count = count + 1;
}Code: Select all
count = 0;
bitsave = var & 0x80;
var = var << 1;
if (bitsave == 0x80)
var = var | 0x01;
count = count + 1;
}Regards Ben Rowland - MatrixTSL
- Jan Lichtenbelt
Re: Rotate left
I think the sortest way to rotate left of the variable Ab will be:
asm MOVF gbl_FCV_AB, F
asm RLF gbl_FCV_AB, F
and rotate right:
asm RRF gbl_FCV_AB, F
and rotate right:
