Azimuth and Elevation Write and Read EEprom
Monie Jacobsen
Has thanked: 17 times
Been thanked: 46 times
Post by Monie Jacobsen »
Hello all
Are there some who will be assisting with the codes in programet "Real-time Solar Position Calculator".
Azimuth counts down, shouldnt only count up in value!
Co-ordinates are entered via the keyboard. (Macro: Set_Coodinates).
Do you help with editing coderne so I can write in my coodinater?
Manually enter coordinates, works fine as here!
lat = 55.121522
long = -10.511286
By write a coordinates go wrong.
But Azimuth counts down. Should only count up in value!
I have attached the program: Real-time_Solar_Position_Calculator
it will be a great help if you want to assist me in getting coderne to function properly.
Real-time_Solar_Position_Calculator.fcfx
(85.2 KiB) Downloaded 438 times
Best Regard
Monie
Monie Jacobsen
Re: Azimuth and Elevation Write and Read EEprom
Is there a possibility to save and retrieve float to and from the EEPROM ,in many separate addresses.
With 2 integer og dot and plus decimal tal.
Want one numbers like (55.121522).
Is there anyone have a sample program which can written and retrieved data from EEPROM and prints on display with decimals.
Best Regard
Monie
Hello Monie,
A float variable is stored using 4 bytes. You can split the float up into 4 bytes by using the following C code.
First place this code into your supplementary code.
typedef union
  MX_FLOAT AsFloat;
  MX_UINT8  AsByte[4];
} MX_FloatUnion;
MX_FloatUnion FloatUnion;
Now you can convert between floats and bytes in your main program using C icons.
You access the bytes using something like this, you need to create four byte variables in Flowcode named F0, F1, F2, F3 and a float variable you want to convert named FloatVar.
FloatUnion.AsFloat = FCV_FLOATVAR;
FCV_F0 = FloatUnion.AsByte[0];
FCV_F1 = FloatUnion.AsByte[1];
FCV_F2 = FloatUnion.AsByte[2];
FCV_F3 = FloatUnion.AsByte[3];
You can then store the byte values to the EEPROM as usual.
To recombine back into a float onc eyou have read the bytes from the EEPROM you can do something like this.
FloatUnion.AsByte[0] = FCV_F0;
FloatUnion.AsByte[1] = FCV_F1;
FloatUnion.AsByte[2] = FCV_F2;
FloatUnion.AsByte[3] = FCV_F3;
FCV_FLOATVAR = FloatUnion.AsFloat;
I use this method in the FAT component to allow for reliable target independent conversion between bytes and longs.
Another way using more EEPROM memory and more processing overhead would be to convert the float to a string and then store the bytes of the string into the EEPROM.
Hope this helps.
Monie Jacobsen
Many, many thanks Benj;-)
I try my way and try to make a program with your coder ..
Best Regard
Monie
No Problem :D
Let us know how you get on.
Monie Jacobsen
Hello Benj
Can not get the codes to function.
There comes Error results regarding EEPROM ...
(241.8 KiB) Downloaded 4607 times
How to convert "." dot, from EEPROM to Display
please will you help with examples of codes that works.
How is this done? Could you give a code sample?
I have attached the program:WriteReadDecimal
I can not get to work... :oops:
WriteReadDecimal.fcfx
(13.81 KiB) Downloaded 422 times
Best Regard
Monie
Hello Monie,
I have chopped out a few bits but here is a simple working example that takes the value stored in the float variable Lat, splits in into 4 bytes. Then takes the 4 bytes and overwrites the value in Lat. If all went well then the value in Lat should be the same as the value you started with.
(9.65 KiB) Downloaded 455 times
Note that the Flowcode variable F0 gets translated to a C variable FCV_F0.
The Union declaration has been moved into the Project Options -> Supplementary code as it needs to sit outside of the macro functions.
Monie Jacobsen
Hi Benj
Many, many thanks for your code example.
Great help;-) :D
Just one question more!
By simulating codes in Flowcode 6 the result is a true in display. "55.121522"
But Boards and display the output wrong!
The show output: 11192660
Has attach the codes!
(8.46 KiB) Downloaded 407 times
Best Regard
Monie
Hello Monie,
Flowcode will not be able to simulate the C code and so was printing out the values you assigned to the bytes. On the embedded hardware the float was being split into bytes and these are the values you are seeing.
I have attached a slightly modified version of the program that should work the same on the sim and the embedded hardware. However note that on the sim the values in the bytes will not be set.
(7.04 KiB) Downloaded 422 times
Monie Jacobsen
Hej Benj
And your big help ;-) :D
Now it works got.
I now work with EEPROM.
I am very happy for your help.
GO Business Day
Best Regard
Monie
Monie Jacobsen
Hello Benj
Want to save and read "Lat" and Long to EEPROM and to ouput Display
By "Lat" alone codes works fine.
But by adding the "Long" go wrong.
Do you want to be helpful with the problem?
Have tried many times.
Has attach the codes! : WriteReadDecimalFloatUnionEEPROM-001
Compiler Nessages:
Target folder: E:\FLOWCO~4\WRITER~1
Source name: E:\FlowCode V6 Projekter\WriteReadDecimalFloatUnionEEPROM-OK\WriteReadDecimalFloatUnionEEPROM-001.fcfx
Title:
Description:
Device: AVR.ATMEGA.ATMEGA2560
Generated by: Flowcode v6.1.2.0
Date: Friday, November 20, 2015 14:10:40
Users: 1
Registered to: Monie Jacobsen
Licence key: ****
http://www.flowcode.co.uk
Launching the compiler...
E:\Flowcode 6\compilers\avr\batchfiles\avra.bat atmega2560 "E:\FLOWCO~4\WRITER~1\WriteReadDecimalFloatUnionEEPROM-001.elf" "E:\FLOWCO~4\WRITER~1\WriteReadDecimalFloatUnionEEPROM-001.c" "E:\FLOWCO~4\WRITER~1\WriteReadDecimalFloatUnionEEPROM-001.lst"
Launching compiler...
E:\FLOWCO~4\WRITER~1>"E:\FLOWCO~2\COMPIL~1\avr\BATCHF~1\..\bin\avr-gcc.exe" -mmcu=atmega2560 -Os -funsigned-char -o "E:\FLOWCO~4\WRITER~1\WriteReadDecimalFloatUnionEEPROM-001.elf" "E:\FLOWCO~4\WRITER~1\WriteReadDecimalFloatUnionEEPROM-001.c" -lm
E:\FLOWCO~4\WRITER~1\WriteReadDecimalFloatUnionEEPROM-001.c:228: error: conflicting types for 'MX_FloatUnion'
E:\FLOWCO~4\WRITER~1\WriteReadDecimalFloatUnionEEPROM-001.c:220: error: previous declaration of 'MX_FloatUnion' was here
E:\FLOWCO~4\WRITER~1\WriteReadDecimalFloatUnionEEPROM-001.c: In function 'FCM_EEPROM_READ':
E:\FLOWCO~4\WRITER~1\WriteReadDecimalFloatUnionEEPROM-001.c:1443: error: 'FCV_Long' undeclared (first use in this function)
E:\FLOWCO~4\WRITER~1\WriteReadDecimalFloatUnionEEPROM-001.c:1443: error: (Each undeclared identifier is reported only once
E:\FLOWCO~4\WRITER~1\WriteReadDecimalFloatUnionEEPROM-001.c:1443: error: for each function it appears in.)
E:\FLOWCO~4\WRITER~1\WriteReadDecimalFloatUnionEEPROM-001.c: In function 'FCM_EEPROM_WRITE':
E:\FLOWCO~4\WRITER~1\WriteReadDecimalFloatUnionEEPROM-001.c:1491: error: 'FCV_Long' undeclared (first use in this function)
E:\FLOWCO~4\WRITER~1\WriteReadDecimalFloatUnionEEPROM-001.c: In function 'main':
E:\FLOWCO~4\WRITER~1\WriteReadDecimalFloatUnionEEPROM-001.c:1575: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards qualifiers from pointer target type
E:\FLOWCO~4\WRITER~1\WriteReadDecimalFloatUnionEEPROM-001.c:1576: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards qualifiers from pointer target type
E:\FLOWCO~4\WRITER~1\WriteReadDecimalFloatUnionEEPROM-001.c:1584: warning: passing argument 1 of 'FCD_0c591_lcd_I2C1__PrintString' discards qualifiers from pointer target type
E:\FLOWCO~4\WRITER~1\WriteReadDecimalFloatUnionEEPROM-001.c:1592: warning: passing argument 1 of 'FCD_0c591_lcd_I2C1__PrintString' discards qualifiers from pointer target type
E:\Flowcode 6\compilers\avr\batchfiles\avra.bat reported error code 1
FINISHED
(13.9 KiB) Downloaded 390 times
Best Regard
Monie
Has thanked: 481 times
Been thanked: 699 times
Hello Monie,
Just a couple of small errors:
1) In your C blocks, FCV_Long should be FCV_LONG
2) In the Supplementary Code, MX_FloatUnion was defined twice.
Leigh
(13.82 KiB) Downloaded 313 times
Monie Jacobsen
Hello Leigh
Ok With Just a couple of small errors!
Many thanks for your work to find fault.
GO weekend
Best Regard
Monie
Monie Jacobsen
Hello Ben and LeighM,
Again thanks for your above examble, they work perfect.
Hope you will help me again. Is it possible to write into a variable (Float) using keypad.
I made many attempts but without success look in att. file.
I want to write to the variable (float) include dot (could be the* on the display) trough the keypad and the same time show the digit in the display and store in EEprom. Is this possible?
I really appreciate your help,
ReadToFloatVarable.fcfx
(16.6 KiB) Downloaded 327 times
Best Regard
Monie
Hello Monie,
Here is a quick example of how I might do it using a string variable.
(12.49 KiB) Downloaded 350 times
Once you have the float you can simply do as you have before and chop the float into 4 bytes to store into EEPROM.
Monie Jacobsen
Hi Benj
Great help;-) :D
Great simplification of coderne.
I try to inplatere write and read "c code FloatUnio" to and from the EEPROM.
Never work with ".Return = StringToFloat $ (.FStr)".
And with ".Return and .FStr". But will try to work with them.
Best Regard
Monie
Monie Jacobsen
Hello Benj and LeighM,
Sorry much my request again.
Can not get file "ReadToFloatVarable.fcfx" to work properly!
Works fine by simulation.
But getting error by Compiling of file: ReadToFloatVarable-.fcfx :oops:
See below on Compiler Messages!
Source name: E:\FlowCode V6 Projekter\WriteReadDecimalFloatUnionEEPROM-OK\ReadToFloatVarable-002.fcfx
Title:
Description:
Date: Monday, November 23, 2015 19:52:38
Users: 1
Licence key: ******
E:\Flowcode 6\compilers\avr\batchfiles\avra.bat atmega2560 "E:\FLOWCO~4\WRITER~1\ReadToFloatVarable-002.elf" "E:\FLOWCO~4\WRITER~1\ReadToFloatVarable-002.c" "E:\FLOWCO~4\WRITER~1\ReadToFloatVarable-002.lst"
E:\FLOWCO~4\WRITER~1>"E:\FLOWCO~2\COMPIL~1\avr\BATCHF~1\..\bin\avr-gcc.exe" -mmcu=atmega2560 -Os -funsigned-char -o "E:\FLOWCO~4\WRITER~1\ReadToFloatVarable-002.elf" "E:\FLOWCO~4\WRITER~1\ReadToFloatVarable-002.c" -lm
E:\FLOWCO~4\WRITER~1\ReadToFloatVarable-002.c: In function 'FCM_EEPROM_WRITE':
E:\FLOWCO~4\WRITER~1\ReadToFloatVarable-002.c:1924: error: 'FCV_Lat' undeclared (first use in this function)
E:\FLOWCO~4\WRITER~1\ReadToFloatVarable-002.c:1924: error: (Each undeclared identifier is reported only once
E:\FLOWCO~4\WRITER~1\ReadToFloatVarable-002.c:1924: error: for each function it appears in.)
E:\FLOWCO~4\WRITER~1\ReadToFloatVarable-002.c: In function 'main':
E:\FLOWCO~4\WRITER~1\ReadToFloatVarable-002.c:2123: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards qualifiers from pointer target type
E:\FLOWCO~4\WRITER~1\ReadToFloatVarable-002.c:2135: warning: passing argument 1 of 'FCD_0c591_lcd_I2C1__PrintString' discards qualifiers from pointer target type
FINISHED
Have attached file:
(14.04 KiB) Downloaded 265 times
Best Regard
Monie
Hi Monie,
From very quick inspection the compiler is saying it can't find the FCV_Lat variable. Try changing this to FCV_LAT noting that the Flowcode variable names are always in full capitals when referencing them in C. Hopefully this should help.
e.g.
Lat becomes FCV_LAT in C.
Flowcode is not case sensitive but the C compilers underneath are.
Monie Jacobsen
Hi Benj,
Have edit FCV_Lat to FCV_LAT and it worked.
Have very little experience to C code.
Have learned a lot by your code examples and would now be able to use them in my projects in the future.
Thank you very much for your great help.
GO 'Workday
Best Regard
Monie
Monie Jacobsen
Sorry much my request again. :wink:
Has written in Lat: 55.12
Has written in Long: 10.1234
But Long is not printed on display correct!
Only integers show no decimal.
What is wrong here?
How do I create variable as ".FStr"?
Have attached file:
(21.81 KiB) Downloaded 301 times
Best Regard
Monie
Monie Jacobsen
How do I create variable as ".FStr" ???
Do you have a short description for the creation of variable ".FStr" ?
Last edited by Monie Jacobsen on Tue Nov 24, 2015 10:32 pm, edited 2 times in total.
Best Regard
Monie
Monie Jacobsen
Is there anyone here who will be assisting with the my project
Writes "Lat" and "Long" variables works really!
Lat save and read correctly.
And works under the simulation.
But "Long" store and will not be read.
"Lat" written right out pådisplay on the test board.
But "Long" not out on display test board.
I think "Long" can not write to or from EEPROM :!:
Can you see where it goes wrong?
I would be very happy if you will assist with the edit codes.
Have work on the problem all day, but without success :oops:
I have attached the codes: ReadToFloatVarable2
ReadToFloatVarable2.fcfx
(24.66 KiB) Downloaded 323 times
Best Regard
Monie
Hi Monie
Your float to byte code has some errors
FloatUnion2.AsFloat = FCV_LONG;
FCV_F5 = FloatUnion2.AsByte[5];
FCV_F6 = FloatUnion2.AsByte[6];
FCV_F7 = FloatUnion2.AsByte[7];
FCV_F8 = FloatUnion2.AsByte[8];
FCV_F9 = FloatUnion2.AsByte[9];
The Float Union AsByte is a 4 byte array, so access them as [0] to [3]
FCV_F5 = FloatUnion2.AsByte[0];
FCV_F6 = FloatUnion2.AsByte[1];
FCV_F7 = FloatUnion2.AsByte[2];
FCV_F8 = FloatUnion2.AsByte[3];
Hope that helps,
Leigh
Monie Jacobsen
Hi LeighM
Thank you very much.
It now codes works as it should
It is my lack of experience with C-codes.
Have no experience with C-codes.
Thank you for your patience.
GO 'working
Best Regard
Monie
Hello Monie,
Variables with a dot before them are local variables. Variables without a dot are global variables.
Global variables are available throughout your program. Local variables are only available when you are inside the macro that use them, allowing better dynamic memory usage.
If you create a local string variable named FStr then to reference this variable you would use .FStr.
In the Project explorer window there is a Globals tab which shows all the global variables, there is also a Macros tab and for each macro you can expand and add local variables.
