Simulation with two COM ports fails
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
When adding two components using RS232 and using simulation there are console tabs for two UARTs (COMPort1 and COMPort2). The properties (after exposing full tree) show COMPort1 for both components and the input/output of one of the channels is (randomly?) listed in one of the console windows. Input of the other channel seems to be ignored (GPS component so no output).
― C.S. Lewis
― C.S. Lewis
Re: Simulation with two COM ports fails
Sounds like this is potentially a limitation of the DLL. We should be able to sort it.
I've passed you the files so you can investigate but can also try and lend a hand if your not getting anywhere.
