12F675 and GP3 as Input
Frank607
Has thanked: 29 times
Been thanked: 15 times
Post by Frank607 »
I have a problem with a PIC 12F675 and a switch on GP3. I have made a simple test program that will one time blink a LED after a switch is pushed.
This program only works (run one time) when the Pickit 2 is connected. If I disconnect the Pickit 2 the program runs nonstop and regardless of the switch.
I have placed the program in this message and post some screenshots from the schematic.
Thanks for helping me out.
Flashing LED with Button.fcf
(8 KiB) Downloaded 541 times
Re: 12F675 and GP3 as Input
Hi Frank,
I'm a bit confused looking at your circuits.
You have got 10K from MCLR to GND
But you have also got 10K+ 470R going from MCLR to + 5V
This means that no mater if switch is pressed or not, the resistors will act as a potential divider and bias VPP at:
10k/(10k + 470R +10k) * 5V
= 2.44V
That's classed as logic 1
So when switch is pressed & released, Voltage on VPP is going from 5 back down to 2.44V
Just remove R17 and R18.
Frank607
Post by Frank607 »
Thanks Martin,
It is working now. I have used this ICSP config with the resistors in all my schematics because this is the “standard” from the ICSP / Pickit datasheets.
But I never used this on a MCLR pin in combination with a switch due to the maximum pins on this chip.
Indeed, this was my error.
Thanks also for the good explanation. It's now clear to me.
Hi Frank,
Your welcome.
Glad to have been some help.
