New to Flowcode but other engineers I work with are using it. We are programming a Pic 24 and I'm looking for a way to transmit data to ATT M2X service. M2X requires API calls to push data to the cloud and I've found plenty of C++ examples but not clear how we would make this work in Flowcode.
C++ Example: https://github.com/attm2x/m2x-serial-mo ... /README.md
Are there any featuresin Flowcode that would support libraries like this? Anyone tried doing something like this? Is there a simpler solution? Any help would be appreciated.
Support Library for Multitech Serial Modem and M2X
Re: Support Library for Multitech Serial Modem and M2X
Arduino libraries can be converted into Flowcode macros to make a component fairly easily but it is a manual process.
Have a go at replicating the functions as macros and then if you get stuck you can post what you have so far and we will try and help out.
