What is the good method to handle a array of bytes (and NULL inside) ?
Than you
Yannick
Array of bytes
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Re: Array of bytes
Hi Yannick,
Can you give us a little bit more information on what advice you would like?
Do you want to iterate through each element in an array via a function or just want to know how to create an array within Flowcode?
Re: Array of bytes
I have two things to do :
1 - Read few bytes in a memory, and return them into an array. If the memory does not contains 0x00, it works. I want to do a function who read N bytes at one address and return these bytes in an array.
2 - I also need to send commands on bus, and the command can contains 0x00...
Thank you
Thank you
Re: Array of bytes
Please can you post what you have so far and we will see if we can suggest ways to work around the problem for you.
Strings cannot have nulls as they have a special meaning but byte arrays should be ok.
Re: Array of bytes
Hello Yannick,
Under the edit post section is a upload attachment tab, this can be used to upload files.(how to post a file here ?)
I think this was added for Flowcode 6 so you cannot do it using Flowcode 5 so we will need to find you a different workaround probably using strings but not the string functions such as length.How to pass or get an array to a function ?
Re: Array of bytes
Thank you Benj.
So with fc5, i must use a global array i think.
I declare a STRING var "mystring[10]" and i use "mystring[0 to 9]".
I have not fc6 at work, we will wait for fc7, do you have a date for it ?
Now i know how to post files... i was looking at top ...
Best regards
Yannick
Best regards
Yannick
- Dan81
- Been thanked: 60 times
Re: Array of bytes
Bonjour Yannick
Ne déclare pas ta variable comme une chaine ("String") mais comme un octet (Byte) avec comme nom : myARRAY[10] par exemple.
Daniel
Daniel
