I have 2 ZigBee XB24CZ7PIT-004 model is possible to run one as coordinator and the other as end devicer or router
, I have been testing, work correctly in the test program, but when I want to communicate at 2 ZigBee, failed to transmit data; I am testing with PIC16F887 (Flowcode5); I have also tested Flowcode6 using the example of a transmitted analog signal (end device) and received by the coordinator on a LCD, but also the transmission of data not work, maybe require using a ZigBee PRO as coordinator
The ZigBee connections made are the same as they are shown in data sheet for EB051 Coordinator and End device or Router.
I'm not using the MAX3002, I have to feed the PIC and ZigBee to 3.3v
Can someone help me realize communication between two ZigBee
Thank you
Enrique
