18F45K50 configuartion for internal oscilator 16Mhz
Salih HORTUM
- Flowcode V4 User
The 18F45K50 configuration does not work properly. I use internal 16MHz oscillator. But simple 10 millisecond delay does not accurate. Please send me sample configuration for 18F45K50 for Flowcode6.
Re: 18F45K50 configuartion for internal oscilator 16Mhz
The internal oscillator defaults to 1MHz on the 45K50 device. Here is an example set to run at 16MHz.
If you attach your program in future then we can offer better help by pointing out what you have got right and what you may need to edit.
