bluetooth hc05
paridhi
Has thanked: 7 times
bluetooth hc05
Post by paridhi »
Can we run bluetooth module hc05 from ECIO-40P by connecting modifying cts and rts pin?
The Rx and Tx features are in flowcode 6 and I have flowcode 5 which shows only CTS and RTS pins in bluetooth component.
Re: bluetooth hc05
The HC05 will work great with the ECIO40P. Flowcode v5 doesn't show the TX and RX pins but does use them, you can ignore the RTS, CTS pins as the HC module doesn't have flow control.
The TX/RX pins should be C6 and C7 on the ECIO device.
paridhi
Re: bluetooth hc05
Post by paridhi »
I tried working with it. But it is not working. I am trying flowcode examples provided on the site.
