I'm hoping somebody can help me with this.
I'm trying to create a flowchart where I can adjust the frequency of the PWM by using a potentiometer.
My objective is to control a small stepper motor. I've done as much as I can would appreciate further help.
Attached is my flowchart......thanks guys.....John
Can PWM be Adjusted?
electron67
- Has thanked: 106 times
- Been thanked: 48 times
Re: Can PWM be Adjusted?
Hi John
this flow chart used to control the intensity of a block of LED of 12 volt, I think you could also work for an motor, you must first enable the PWM option
Enrique
Enrique
- PWM.fcf
- flowchart
- (8.5 KiB) Downloaded 614 times
electron67
Hi John,
Sounds to me like you will need to vary frequency of pulses rather than duty of PWM.
You would also need to control the pulse count.
This sounds like the job of the built in stepper motor component (Mechatronics Menu)
Just add it to control panel then right click on the component and select help to view options, or select External Properties to select the type of stepper motor it is.
Or
You can use a timer interrupt.
You can't have pulses to fast or there will be slippage.
Using a count variable you can vary the frequency output.
Going back to stepper can you supply details of the stepper motor and driving circuitry so we can take it further.
Or
