I using Displaytech 64128Q 128x64 dot matrix lcd (controller/driver SB6400G-D/SB0064, eqv. KS0108). Problem: print text message not visible or not working. Draw rectangle and line it's work. I probably setting foreground and background colors (properties panel and componens macro-lcd) and search the forum similar problem, but did not succeed. If i using the print function (text or numbers), sometimes vertical lines draws the display (left top => right bottom). I using Flowcode 6.1.3.2., trying previous version (v. 6.1.2.0.), and in the forum repaired gLCD_KS0108.fcpx. Any ideas?
P.S.: Sorry my bad english.
