Help with an eagle part design please
Steve001
Has thanked: 460 times
Been thanked: 523 times
Post by Steve001 »
Hi All
Anyone good with eagle ? need help i am trying to make a texas inst OPA569
http://www.ti.com/lit/ds/symlink/opa569.pdf
Struggling making the thermal pad design with the exposed pad and the via's to the pad on the bottom layer and how do i make the connections to multiple pins as various functions are across two pins of the ic ?
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Help with an eagle part design please
Post by kersing »
Have you considered trying cadsoft community resources?
― C.S. Lewis
EtsDriver
Has thanked: 345 times
Been thanked: 227 times
Post by EtsDriver »
To get multiple pins into one function, you can just use ctrl to select them all from the pad desing in the device creation, and then you click the connect button. they all will be grouped under one name, and the schematic symbol then needs only one pin for all the same pins... :) I have never gotten an way to have thermal pads to have via in my desings, but i think usual VIA could be fine...
Made a little dummy demostration:
used smd pads to make the "component", here its blown up to demostrate all the parts used to create powerpads...
And the connections:
select powerpads_to_pin.JPG (51.4 KiB) Viewed 5831 times
Steve001
Post by Steve001 »
Just an update
I Have since found out that what i am trying to do with my package design is not possible in eagle
I was wanting to make the pcb foot print complete with the copper heat pads and vias so when you pick the part it's all done for you rather than doing it manually afterwards
another issue was when you have multiple pins for input and out puts and you have big track widths to accommodate the current sometimes you get overlaps on the pads.
I wanted one common pin for the two that would sit in the centre so this was minimised.
The way round this is to group the pads and use polygon function.
bit disappointed but i have a work around
