i'm working with the evaluation version of V6 Flowcode.
My first program was to test a Graphical LCD from 4Dsytems: see attachment, very simple program.
used controller: Atmega128/AVR
serial port output selected: channel 2 on PORTD: PD2/PD3
in project options: 16Mhz, Atmega128 selected as my hardware board
As a first test i wanted to draw a simple line on the touchpanel of the graphical LCD. The simulation works on my system panel but when i downloaded the program to the microcontroller: no reaction.
Then, i disconnected the serial port from the gLCD to measure the output on PD3 to see if commands were sent out from the serial port TXD1/RXD1 (or: channel 2).
My oscilloscope shows me there are no serial commands coming out. The problem seems to be that the serial commands are not sent to the gLCD
Is it possible that this is not working with the evaluation version or do I have to do more settings before i can use this mini touchpanel?
please help
tx!
